interesting but not seeing how that would work with tube tires. Someone had mentioned Meyers. Can only get box of 25 for $80 and a 40 day leadtime. Seems like rubber sheet and 1300L will net same result as balance patch except that it might be a bit bigger. Tube would hold it in place. All purely hypothetical of course.
Balance the installed tire. 8:50 airhawks. Can’t put enough weight on little 6” wheel to get them balanced. 2oz out on the tread takes care of it. IN the tire btw
Look at their web site. They talk about installing in tubes.interesting but not seeing how that would work with tube tires. Someone had mentioned Meyers. Can only get box of 25 for $80 and a 40 day leadtime. Seems like rubber sheet and 1300L will net same result as balance patch except that it might be a bit bigger. Tube would hold it in place. All purely hypothetical of course.
Happen to be at an IA renewal meeting and not surprisingly tire guy says gluing rubber in tire bad idea. Tube chafing being the concern. So...moral of the story, spend money on good tires. Avoid Airhawks. If you’re concerned about balance anyway.
