Page 1 of 2 12 LastLast
Results 1 to 40 of 41
Thread: Landing lights in the gear
    Charlie Longley's Avatar
    Jan 2008
    Arlington, WA
    576
    I see a lot of cubs with landing lights in the gear. Whatís the sign off on certified airplanes?
    10,573
    Minor. Bolt on. Some reg about not reflecting on prop/pilot
    1,805
    Had one for 14 years. Better to see the things that break gear. Minor and improved safety. Wing lights are for runways not hazardous terrain.
    Thanks hellojac thanked for this post
    1,805
    There's some nice high intensity LED driving lights now that are aerodynamic especially for motorcycles like BMW. Back when I used a Warn truck spot light bolted to the ADodge safety cable center bracket. After I hit a duck on floats with my left wing PA-18 light I removed that useless light location and put one on the gear. It made seeing snow drifts and sticks/rocks much easier. Being low and set pointing ahead three-point landing made the prop reflection minimal.
    Feb 2009
    67.8N,115.1W CYCO Canada
    833
    Thinking of bolting a 20-inch LED light bar to the cabane. Would this help with a ski landing in flat or semi-flat light?
    Feb 2009
    833
    Gary - we were posting at the same time. Thanks for the info.
    Larry
    1,805
    Quote Originally Posted by NunavutPA-12 View Post
    Larry
    Hi Larry. LED color might be critical in winter. Here's some options for snow visibility:
    https://www.xenonpro.com/led-headlig...ing-best-color
    https://www.powerbulbs.com/us/blog/2...r-whiter-light
    I wear ambermatic darkening glasses that filter out part of the blue color spectrum. I can see snow definition better with that amber/yellow color especially on a flat light day or at night when everything in the terrain blends together. Scattered light rays cause that: https://www.sportrx.com/blog/snow-go...for-low-light/ <and> https://www.seniorsskiing.com/coping-with-flat-light/
    Thanks NunavutPA-12 thanked for this post
    cubdrvr's Avatar
    Jan 2002
    1,130
    Thanks NunavutPA-12, Charlie Longley thanked for this post
    9,889
    LED light are evolving fast. One of theses is probably all you need?
    2 years ago a light this size could only be found at 288 watts max
    https://rover.ebay.com/rover/0/0/0?m...2F153630408180
    Even better
    https://rover.ebay.com/rover/0/0/0?m...2F254081747851
    1,805
    I'v wondered over the years why someone hasn't adapted a light to the air cleaner dome or winter oil cooler opening? May be too much prop blockage but Cessna and Bellanca/Citabria got away with it ok.
    Likes Hardtailjohn, daedgerton liked this post
    Feb 2009
    833
    I might try mounting it on the lower cowling instead of on the cabane. On my 'plane mounting on the cabane will put it directly in the exhaust stream and grime from the breather.
    1,805
    My Cub's cabane V light got skunged up from the breather. Wiped it off with filter fuel. Eventually the fabric on the belly downstream started to ringworm I guess from air flowing off the top of the big lamp. A small LED might not do that. Sure was nice on flat light days or at dusk after a long day trapping to be able to see snow drifts better. One time I flew from Nenana to Fairbanks in the dark with it on and sure appreciated the illumination of the river below and trees along the banks for reference. It was snowing and I got a late start home. Lights on the wing can make flying in snow more difficult than having them below the engine.
    Jan 2008
    Arlington, WA
    576
    That's where it's at in the Pawnee. Different air filter of course.
    behindpropellers's Avatar
    NE Ohio
    6,725
    Thought about it but its already a lot of overhung load on the carburetor.
    1,805
    Yes that could be a challenge to fix. Maybe a brace like Continental uses on their small airboxes?
    daedgerton's Avatar
    Jul 2015
    Arlington, VA
    133
    Yep! And so did Mooney... Had a wig/wag on my Mooney and loved it. Could see me for miles...
    I'd like to do this as well...
    My A model has no landing lights in the wing. I don't need it for landing as I rarely fly the cub at night (I'm a helo guy and fly NVG's all the time.. side note: I would love to fly NVG's in a Cub but that is a whole 'nother controversial topic).
    back on track... I'd like to have this so I could have illumination if needed, plus I love to be seen by everyone. I'd also like to incorporate the cabane light as a wig/wag as well...
    1,805
    The cabane light is a quick job as there's hardware already there to attach something to. LED's can be seen for many miles especially if cycling power even in daylight. The wide angle fog versions might be better for see-me visibility and a spot version less up angle reflection in snow, rain, or fog. But.....maybe just installing some led's in or on the airfilter dome would be good enough.
    Earlier discussion here: https://www.supercub.org/forum/showt...ht-LED-options
    Likes daedgerton liked this post
    Clearwater,Fl
    2,539
    I have a 250 W GE mounted so the element is vertical. Over 1400 hours hung directly in prop blast mounted to my belly pod. Truly amazing. I haven't done a comparison lately but at the time it had more candle power in 2011 when I installed it vs the LED's. Curious how it compares to LED's today.
    18,958
    I was watching Mike Patey's latest video and he showed his wife installing some nice LED lights on her Carbon Cub cabane vee. He said who made them but my wife wasn't there to tell me what he said. Rewind and still couldn't understand what he said. Looked like they were made for the cabane.
    Likes cubpilot2, 40m liked this post
    Dec 2016
    Canyon, tx
    447
    https://aeroleds.com/products-microsun/
    I’m a mumbler so I can interpret other mumblers.
    Likes BC12D-4-85, cubpilot2, Jonnyo liked this post
    cubpilot2's Avatar
    May 2003
    Anchorage Alaska
    748
    $350.00 each at AC Spruce.
    https://www.aircraftspruce.com/catal...ickkey=3009501
    Ed
    18,958
    Some clamps on the cabane would be easy. They are bright and built in wig wag.
    Attached Files Attached Files
    cubpilot2's Avatar
    May 2003
    Anchorage Alaska
    748
    I see they also make a landing light replacement with built in wig-wag as well.
    The clamp on feature is great.
    Steve: Have you been treating these as a minor change as well? Sure looks like one to me.
    Sometimes I wish I had a flashing LED flood light shinning back, similar to Draco. I think it would be better then the small strobe as I get a bit nervous with all the faster traffic crowding me when heading into lake hood.
    Ed
    18,958
    I haven't yet, ordered a pair today and intend to install via a logbook entry. I don't see where in falls under the definition of a major alteration. Been throwing around ideas on a clamp system and weather proof plug to mount them on the cabane Vee
    CenterHillAg's Avatar
    Texas Coast
    101
    Most any ag plane running around with a fan brake on the chemical pump is using a 2 pin flat plug for the wiring, it would probably be fine for the light connection. I spray my connector with CRC SP400 and have a neoprene velcro wrap I put around it, it’s holding up well.
    Jan 2008
    Arlington, WA
    576
    This got me thinking. Are there many Super Cubs with a second set of landing lights in the right wing? Maybe set up to wig-wag?
    Dec 2016
    Canyon, tx
    447
    Tom Ford’s. One light in each wing. He split the two light receptacle I think. If I was to have one rebuilt, I’d do the same thing. Maybe he’ll chime in
    2,784
    Ive seen people that wigwag the two-light fixtures,
    but I've heard that wigwagging two lights right next to each other results in what from a distance looks like a single light thats on steady.
    I have one standard bulb & one led in my wing light fixture,
    with a flasher in the led's circuit.
    Not quite as good as a true wig-wag on both wings,
    but it does help.
    2,622
    but it does help.
    Correct about wig-wag two lights close together. If you have two lights in each wing you'd need to figure a way to flash both lights in each wing, alternating wings, or all four on/off together.
    Also, A MaxPulse controller will work with a mix of lamps such as one LED and one incandescent.
    RaisedByWolves's Avatar
    Feb 2005
    3,855
    I cut the factory landing lights in half and put one in the left wing and one in the right with aero led sunspot with the built in pulse.
    Feb 2005
    3,855
    Thanks Charlie Longley thanked for this post
    Feb 2005
    3,855
    https://www.instagram.com/p/BkY17TQA...d=4euw4ve4dhzl
    4,812
    Maxpulse has settings for alternating or simultaneous flash with multiple speeds for both. It also allows steady on for either or both lights, and all off, too. For closely mounted lights like those on both my planes I use simultaneous flashing at 44 ppm. With any flasher setup Iíve seen LED bulbs are far better than incandescent because they cycle from off to on instantly while incandescents are like fiddling with a rheostat on your dining room lights. LEDs blink, incandescents vary brightness slowly. And FWIW, the Maxpulse doesnít last long when flashing 100w halogens. Not in my experience, anyway, and Iíve bought a few Maxpulses for my planes. Personally I donít think two wing lights flashing alternately provide any recognition advantage over dual nose lights flashing simultaneously. The bigger consideration when choosing lights for recognition should be width of the projected beam. Flood beams are better than spot beams.
    2,784
    …. I don’t think two wing lights flashing alternately provide any recognition advantage over dual nose lights flashing simultaneously....
    I've never compared them side by side, but
    I'd think the alternating left-and-right would provide more apparent "movement" to catch your attention.
    My first experience seeing flashing landing lights was on Kenmore's Beavers around Puget Sound--
    that's what they do, & you notice them a along ways off.
    Jan 2008
    Arlington, WA
    576
    Did you do that with a log book entry Tom?
    Feb 2005
    3,855
    Yeah. I duplicated how piper had them installed and copied it for the other side. Itís identical to stock except itís half the size.
    55-PA18A's Avatar
    Dillingham, Alaska
    606
    Yeah. I duplicated how piper had them installed and copied it for the other side. It’s identical to stock except it’s half the size.
    ?? Piper part and "installed as per Piper drawing" ??
    Jan 2008
    Arlington, WA
    576
    i am leaning towards doing that in my SC project.
    2,784
    Personally if i was going to the trouble to add lights to the other wing,
    I'd just put the double lights on both sides.
    Jan 2008
    Arlington, WA
    576
    I am going to try and keep the weight down.
  1. PA-12 Landing lights
    By Grouser in forum Cafe Supercub
    Last Post: 12-05-2012, 09:00 AM
  2. landing lights
    By arizcub in forum Member to Member
    Last Post: 04-22-2011, 09:23 PM
  3. LED Landing Lights
    By skywagon8a in forum Products, Purchases, Reviews & Prices
    Last Post: 04-19-2011, 04:27 PM
  4. Landing lights
    By cgoldy in forum Experimental Cubs
    Last Post: 11-07-2010, 05:06 PM
