mvivion
SPONSOR
Actually, I gave that considerable thought as I was wiring the plane. I bundled wires that were anywhere close to the compass behind the panel such that their magnetic field vector would be vertical in the vicinity of the compass. The intent was to not interfere with the horizontal component of the earth's field. At first, it was great, but like I said, gradually degraded and was independent of radio, lights, etc being on or off. I don't know why. Maybe high current fore/aft wiring, like for starter or alternator had an influence on the frame even though at a distance from the compass. I considered degaussing, but decided against that effort because whatever caused the problem would undoubtedly reassert itself.
One of the problems with compasses in aircraft is that an airframe actually becomes more magnetized as it moves through the air. Friction is a powerful force.
Consider the submarine. All US submarines go through degaussing periodically to reduce their own magnetic field. The "stinger" you see on the tail of an anti submarine aircraft like the P-3 Orion is a "Magnetic Anomaly Detector", or MAD system. It can actually detect disturbances in the Earth's magnetic field, including a submarine, which is a pretty big chunk of metal. But, by degaussing the submarine periodically, that disturbance is minimized.
In my experience, the Vertical Card compasses, and the SIRS compasses both can work when hung somewhere high in the windshield, as Gordon describes. In a couple of cases, I found that the Vertical card compasses also required installation of compensator balls, which are available for them.
Look at the large compass on many ships....surrounded by huge quantities of steel. Many if not most of those compasses have some sort of compensators installed as well.
That said, I've had SIRS compasses in two airplanes that I couldn't get a standard compass to work in, and the SIRS worked very well in both with no compensators.
