Results 1 to 18 of 18
Thread: Exhaust Nut Torque
    Apr 2010
    Crane Lake, Minnesota
    45
    Exhaust Nut Torque
    Seems to be lots of opinions and ideas out there. The Lyc book I have shows exhaust studs at 40 inch lbs minimum. Does anyone out here know or suggest what the hold down nuts should be torqued to? Thx
    10,643
    As loose as they will stay on. Or else the flanges bend(with no blow style gaskets). You can sand the flanges flat again a few times before the must be replaced
    4,885
    A good place for Nordlock washers.
    Likes mike mcs repair, cubflier liked this post
    6,896
    Interesting. We smaller Cub owners use brass nuts. Over-torquing results in stripping. But Clint has these neat stainless steel flanges he welds on, and it would take way, way more than 40" lbs to make one banana-shaped.
    19,049
    I have not found a current torque value for the exhaust nuts in any current publication from either Piper or Lycoming. The best thing I have found was in the Jan 1973 Table of Limits that has been superseded which gave a value of 160-180 in-lbs.
    10,643
    and for those who haven't seen them... cool stuff, order some samples and try them...
    I stock them now... no comparison!!!
    10,643
    4,885
    Thank goodness. Spruce has simplified the ordering process a great deal! I just spent $150 on lock washers ahead of my engine install. Worth every penny, too.
    If you haven’t tried them? You ought to. They work.
    Jun 2015
    144
    Steve is correct. 160-180 inch lbs is what I recommended for many years.
    Likes Bill Rusk, jnorris liked this post
    RVBottomly's Avatar
    Sep 2017
    630
    Timely for me. I've been working on a hardware order for the last week and was trying to figure out which way to go.
    Vic
    4,885
    My order was quickly filled and shipped from Spruce’s Alaska warehouse. That’s my second order of parts, hardware, and gaskets that have come from the local warehouse recently. Very handy for Alaskans!
    9,625
    I use these nuts on the Lycomings as well. They are deeper than the steel Lycoming nut, lock washer and flat washer and they don't rust from the heat. Just run a course thread tap through them, since they are intended for the fine threaded Continentals. They are long enough to cover the entire stud preventing heat and rust erosion of the stud.
    Likes cozzmo81 liked this post
    19,049
    The STD-1410 factory Lycoming nuts Aircraft Spruce Part# 08-13229 are stainless and I have nut had any rust issues. Their studs are the same and no issues.
    https://www.aircraftspruce.com/catal...clickkey=45483
    9,625
    I Have seen a lot of rusted studs over the years. Some rusted so much that the nuts will not back off and pull the studs out with them.
    19,049
    Same here, that is why I replace with the stainless. No fun doing the Piper Exhaust AD every 50/100 hours
    6,896
    I insisted on the muffler terminating that AD. Nobody was doing it except me, and I hated the job. Never seen a Super Cub without stainless nuts - but have the Heicoil kit ready anyway.
    AkPA/18's Avatar
    Feb 2003
    Big Lake Ak
    661
    I also recommend the stainless nuts and I also put a little dab of hi temp RTV inside the nut. This coats the stud as you install the nut.
    http://thrustline.com/
    10,643
    Quote Originally Posted by AkPA/18 View Post
    ..and I also put a little dab of hi temp RTV inside the nut. This coats the stud as you install the nut.
    that's what I heard also from a Cordova guy too....he slathers the studs too.... says it helps...
  1. Replies: 14
    Last Post: 12-15-2015, 04:23 PM
  2. what is the torque value for exhaust NUTS on 0-320
    By BOB HANCOCK in forum Super Cub Sick Bay
    Last Post: 04-14-2015, 11:36 AM
  3. Leading Edge Exhaust -- Exhaust Odor in Cabin on Final
    Last Post: 06-01-2011, 09:02 PM
  4. Exhaust stud torque
    By skukum12 in forum Super Cub Sick Bay
    Last Post: 09-10-2006, 02:27 AM
