Electric Beaver
If the concept can work anywhere, it’s with those guys. They fly short legs. Interesting to see how much down time they’ll have for charging.
Mike, the article said 30 minutes charge for 30 minute flight "currently" (pun intended...)
Outstanding!!! Electric airplanes.
At 500/hr per year, 24 gal/hr. x $5.00/gal. that a $60,000/yr. savings on fuel alone and more savings on maintenance.
With the Beaver’s enormous useful load, big batteries can be carried in the belly without affecting passenger count.
And a 750HP Beaver should take off like a helicopter. I wish I was 18 again.
That is a lot of coal they are going to have to burn to generate all that electricty for charging. Solar, wind cant carry the complete electrical load society demands.
It reminds me of the adage, the first 80% of the results take 20% of the effort. This plane has the entire passenger compartment filled with batteries and has 15 minutes endurance. The main obstacle to electric planes are the batteries, which need sufficient density and resistance to fire, and Harbour hasn't said how they're going to overcome it. I genuinely hope they have success, but I don't see it happening any time soon based on this demonstration.
Who'll be the first to build a STOL contest plane with an electric motor? Very lightweight, very high torque, short flight times. It would be a good fit.
I read somewhere that Harbor is reporting 60 min recharge times. I don't know if that's for the 3 minute demo flight or for longer duration flights, but 60 minutes is pretty quick. Gotta applaud dreamers and developers.
G44: you’re right. We should stop trying to improve e-tech and stick with old-fashioned gas burners. After all, only one has the certainty of destroying the environment.
Stop flying now!!! Scrap airplanes, walk to work, and eat vegan.
BTW, what ever happened to the fuel replacement for 100LL?
I watched a video of the takeoff and it was loooong (they said it was downwind, but there wasn’t much judging on water) and the pilot was working really hard to get it to fly.
The motor is apparently limited to 450 hp
A couple of years ago, during a safety meeting at a Repsol LNG plant, a supervisor held up containers of products that packed a lot of energy for it’s size; dynamite packs a lot of energy for its size and a small number of other products like gun powder. Then he held up for the class to see a one litre clear bottle of gasoline. “Nothing” he said, “compares to the energy given from this product for it’s cost and availability”. Never forgot that.
While it is impressive the efforts to switch to something better and greener, at present, it’s along way off from being anywhere near viable. Also, hidden from view, and never ever looked at by the media (most of them), is what the impacts are to build, in mass, and dispose of these batteries. Nor the cost.
Imagine trying to charge they plane up by solar in Vancouver. Not happening. Were there any media reports of who paid for this Beaver to be converted and tested? Perhaps the makers of the motor and the charter company themselves, although it wouldn’t be surprising if public dollars were involved. Green gets attention these days.
Far better for research to be done for the improvement of gasoline engines IMO.
I think electric aircraft are going to be the trainer of the future. One they start showing up rapid charge stations will be close behind. A lot less hassle then trying to get a fuel tank/tank pump approved at a runway. They will have issues/growing pains but that occurs with anything.
So you've unplugged from the grid and power your home with a gennie? If not? Why not?
Some of these posts are VERY entertaining, lol.
I don't hold much stock in an all electric aircraft but for much more practical reasons (at least to me). First off, simple weight and balance. Electric motors can be made for great torque, but any type of motor can be relatively heavy. Go browse the threads that discuss O-360 vs O-320. One side says 'more horse power, while the opposing side says 'extra weight'. The electric motor installed on this Beaver is supposed to be rated for 750 h.p. I'd like to see the weight of that exact motor and compare it to the weight of a P&W PT-6 or Garrett 331. Those will produce 750 h.p. and 1000 h.p. when mounted on Beavers/Otters. Then lets take the 'fuel source'. How much does the battery pack, alone, weigh? Compare this to the weight of a full load of kerosene. Now calculate the horsepower to weight for electric vs turbine. As an afterthought add to that, the time in flight available for each system.
Now consider the size of the battery pack and how much cabin space will be needed for it. Wet fuel goes under the floor in a Beaver, so no lost space. How about safety of the crew in a crash. If you're of the green persuasion, how about the environmental concerns after this battery pack is broken up. On land, in fresh water, in salt water.
Not a hater, not a fan, yet. But I sincerely hope they keep working on reducing weight and increasing time of flight. A smaller aircraft, say a two seater, with about a two hour flight range would seem to be doable. Until then I'll trust in a proven design
Hybrid, like my Prius, makes more sense, with current tech. E power+plus ICE for takeoff, ICE for cruise. Regen during descents! I descend 1200' every day driving on the way to work, and with the Prius I get 3 miles + extra range, once on level ground, free, plus save brake wear. Friction brakes only, like my 1 ton Chevy, seems archaic in comporasion. Red light? Chevy idles, Prius shuts down. Prius drivers are known to look smug, ( or maybe constipated) that's why. Romp on the throttle, like I do entering I -15 every day, and they can move out quite smartly, and I still average 100 to 700 mpg on my 13 mile commute to my crane yard. Depending on OAT, ICE will come on just to keep it warm, summer time not so much. The money the Prius saves me over driving the 1 ton, buys gas for the plane.
348hp from a 110# motor would be pretty sweet. Imagine coming home, unplugging the airplane, flipping a switch, and going to full power with no warmup. I'd like it. No fueling, no heat or cooling worries, no leaning, no loss of power at altitude, etc. It likely won't happen in my lifetime but the next generation will only know about gasoline from history books.
I’d like to see it successful and put the heat on P&W and their antics in the turbine market. PT6 parts and pricing are getting past the point of stupidity.
I've ridden my Montague folder ebike above 9K several times, And yes, could detect no loss of power in the 1300 watt motor, a neat side benefit. A noticable difference as compared to my own sorry ass.
There are still plenty of heat related issues in motor controllers and battery systems.
Not to mention the extreme weight of the power supply, the batteries are evolving and pretty damn good in ground vehicles. But still not ready for a usable aircraft.
I expect for a training plane, quick swapable batteries could bring the duty cycle way up. Would work well for the Beaver too if not for required flight reserves.
We do pay allot for gasoline, but it is cheap when compared with alternatives such as cost of batteries and their charging systems. That is clearly changing though.
I commend companies such as discussed here who are pioneering the path for others. But I hope projects like this do not bankrupt them.
Someone just clued me in to Formula E. Great, I thought, a showcase for the pit crews swapping battery packs. Or add 20 points of charge in a minute or two. Anything to show the public how far we've come in practicality. He showed me a video of the drivers hopping from one car to another!!! Yeah, that'll do it.
There has been a lot of talk about rapid charge stations. Are there any batteries which can take repeated recharging in less than 10 minutes without melting down? I have yet to wear out a gasoline tank unless they were made of rubber.
It appears that battery technology is the key to flying with electric airplanes.
Bingo
At the Pikes Peak hillclimb we are seeing tremendous performance from both electric cars and bikes.
A few years back one of Toyota's battery chargers was damaged in a road accident on its way to the event.
They had to get one shipped in from Japan to be ready the next morning. The cost of shipping was beyond most competitors overall budget for the event.
The Brits who bring us most hyper performance track cars have a super high performance electric car. It is impressive to see what AWD offers when each tire provides it's own computer regulated thrust and braking.
But for each 30 min track session you need a company provided crew to swap the two battery packs out which weigh in the order of 3000 lbs. This needs to be done right away in order to cool and stabilize the cells.
