Page 3 of 3 FirstFirst 123
Results 81 to 84 of 84
Thread: Lower cowl scoop shape
  1. #81
    4,905
    Two coolers. Both have outlet ducts. These are 9 row. I had excess cooling capacity and thought about switching to 7s but the new motor will make more heat so not now. That cowl you have has been a struggle for many other guys before you. Especially with parallel valve motors.
  2. #82
    Jul 2016
    Maun, Botswana
    67
    if a 13 row oil cooler has a 5,5X5,5inch "face" its effective orifice is less than that because of the fins and cooler rows, does anyone know what this factor is for a 13 row aero classic oil cooler? my rough guess is about 30% of the area is "covered" up by the fins?
  3. #83
    4,905
    Not familiar with Aero Classic but Niagara provides air pressure and heat rejection specs for all their coolers. Yours would compare to a 20006A.
    https://niagaraairparts.com/products/
    Thanks bodumatau thanked for this post
    Likes bodumatau liked this post
  4. #84
    Jonnyo's Avatar
    May 2014
    Fairbanks, Ak
    130
    [QUOTE=bodumatau;764579]copy that NP1A, #1 has never been a problem though only #3, but I hear you, I will trim it back a little.
    Ramps in front cylinders 1 & 2 that end halfway up the cylinder are good practice. However, the left edge of the ramp in front of cylinder 1 should have a lower angle, so that the fins next to that exhaust valve are not get blocked off. Bending down the corner of the ramp down at a 45° works.
    Jonny
    Likes barrow pilot liked this post
  1. PA-18 Lower Cowl Drawing
    Last Post: 09-25-2019, 06:43 AM
  2. Nose Cowl W/O Oil Cooler Scoop
    By GeeBee in forum Modifications
    Last Post: 02-12-2013, 11:41 AM
  3. PA 18-95 Lower Cowl Profile
    By Mark Lund in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 11-25-2006, 05:38 PM
Tags for this Thread
