Results 1 to 19 of 19
Thread: Lifting Eyes for J-3 Cub
    Feb 2004
    26
    HI Folks,
    Does anyone know where I can find Lifting eyes for a J-3??? Thought Atlee Dodge would have them for sure, but they have only for supercub. It is a Certified airplane so looking for PMA types. Any help would be appreciated.
    Mark
    9,845
    Call Browns SPB and ask what they do
    Thanks Quazzi thanked for this post
    1,706
    I have helped others use a soft strap or rope around each spar under the front upper wing fairings tied to a spreader bar. FAA PMA'd parts of course.
    10,530
    Lifted mine (carefully) by the base of the engine mount. A number of times. Be careful and it works.
    nd
    3,305
    wonder how that would work? on a j3 the front spars attach in the middle.
    1,706
    #3 worked on my PA-11 until we got a FA for permanent lift eyes. Metal spars on that one tho. Under the wing roots live the exposed spars. Wrap once all around so they can't slide and up she goes. Motor mounts work if the tail can be maneuvered during the lift.
    AdirondackCub's Avatar
    Jul 2012
    Ballston Spa, NY
    146
    Burl aircraft in AK makes one for the J3 that mounts where spars join. It's one piece and 4 bolt holes with lifting eye. That's the one.
    2,573
    SOMEONE explain why a lifting eye needs a field approval or PMA, etc?
    Likes bob turner, RaisedByWolves, Quazzi, DENNY liked this post
    1,706
    For lifting eyes that go under an inboard spar/fuselage fastener component N/A I assume...like Piper, Taylorcraft, Champ. For my PA-11 the FA was for AD's Piper outboard tie down bracket installed on the spar at the wing root pointing up. Could have put two lift eyes at the center spar/fuselage connection I guess but it wasn't my job.
    18,832
    Atlee Dodge lifting eys don't have a PMA. http://www.fadodge.com/lifting-eyes/
    Feb 2004
    26
    Hi Gary,
    Rope and Strap has always worked for me, but when I bought my floats from a guy with lifting eyes on his J-3, I had to have them.......he was the third owner and didn't know where they came from....
    Feb 2004
    26
    I'll give Burl a call.....Thanks for the info.....I have metal spars on mine.
    Mark
    Feb 2004
    26
    Hi Steve,
    Thanks for pointing that out......Maybe I need to understand better PMA and FA. I bought weld on float fittings from Atlee and they PMA'd. The PMA for the lifting eyes was an Assumption!!!
    Thx,
    Mark
    2,573
    Welding on structure constitutes a major repair/modification. Installing a steel tab with a bolt does not.
    Likes DENNY, supercrow liked this post
    9,472
    Quote Originally Posted by Quazzi View Post
    Mark
    The PMA only means that the parts are approved as designed and authorized to be manufactured. It Does not authorize the installation on any airplane.
    GCyr's Avatar
    Nov 2013
    Augusta, Me
    8
ID:	45971Click image for larger version.
ID:	45972This is what it looks like from burls make sure you check the measurement of where your spars connect in the center the one they sent me was 2.5 inches center to center. It didn’t work on my experimental cub I ended up just making one myself.
    Dave Calkins's Avatar
    Jul 2002
    Anchorage, Alaska
    5,388
    I hadnt seen Burls J3 tab. nice! He makes nice stuff.
    Have been using a strap around the spar junction after removing a fairing for years.
    Eyes off metal spars like a SuperCub would be very nice and more stable than a “centerline” pull
    Feb 2004
    26
    Thx GCyr.
    Just saw your post...Thank you for taking the time to send the details. Putting the ruler next to it really helps.
    Take Care,
    Mark
    Oct 2006
    Seldovia, Alaska
    149
ID:	46130LClick image for larger version.
    ATLEE lifting eyes for 18. Bolt on. Minor alteration. No STC required only log book entry
    Likes AkPA/18, 46 Cub liked this post
  1. Lifting Eyes
    By Eddie Foy in forum Cessna: C180/C182/C185
    Last Post: 07-03-2018, 11:05 AM
  2. Replies: 7
    Last Post: 09-28-2017, 02:04 PM
  3. SC Lifting Eyes Spreader Bar
    By McAlpine in forum Member to Member
    Last Post: 03-11-2017, 09:30 AM
  4. Eyes Right
    By cubdriver2 in forum Cafe Supercub
    Last Post: 03-15-2012, 09:38 PM
  5. tricks, lifting eyes, gps ant, eyebrow fairing
    By mike mcs repair in forum Tips and Tricks
    Last Post: 05-16-2011, 02:50 PM
