Results 1 to 13 of 13
Thread: Lexan to Lexan Glue or Adhesive
    nd
    3,305
    Im looking for a glue or adhesive for gluing lexan to lexan that gives a strong bond, going to glue square lexan tubing to a lexan flat sheet. anybody have any experience with this with good results on a product to use? need something that will give a minute or 2 of time to work with.
    nd
    3,305
    CenterHillAg's Avatar
    Texas Coast
    92
    Ever tried Shoe Goo? I can’t say I’ve used it on Lexan, but I haven’t found much it won’t stick to and have a good bond.
    Vermont
    249
    I had a gas cap at the base of a lexan windshield, replaced the windshield 3 times. You don't need a drop of gas, just the fumes will crack it. If there's any whiff of solvent, lexan will crack.
    What's a go-around?
    Dec 2004
    Inkom, Idaho
    1,371
    Look no further! LEXEL. White or crystal clear, been working for me for 12 years on my lexan skylight, on a lexan to lexan lap joint. Also on my Plexi windshield /lexan juncture. An adhesive caulk, emphasis on adhesive, paintable, stays flexible, I love the stuff. Ace Hardware, big gun tubes, and smaller 5 oz. tubes.
    4,705
    Methylene chloride plastic welder. I'm pretty sure that's what I used on my Cessna strapless windshield that requires gluing a doubler to the top edge. Supposed to work equally well on acrylics and polycarbonates.
    18,832
    I have a tube of stuff at the hanger specifically made for glueing Lexan. Works well. Will get a photo of it tomorrow.
    nd
    3,305
    curious to see if its this weld-on 16, sortve what i coming up with. i believe it has that methylene chloride that stewart mentioned.https://www.tapplastics.com/product/...SABEgIKRvD_BwE
    Dave Calkins's Avatar
    Jul 2002
    Anchorage, Alaska
    5,388
    Be careful with Lexel and large gaps. It will continue to shrink over the years. Also, the white Lexel will yellow over time.
    And Lexel stinks, and stays kindof “sticky” for awhile.
    In my experience with about 4 tubes I have used over the years
    9,845
    Don't get Plexiglass ( acrylic) and Lexan ( polycarbonat) confused. 2 totally different compounds
    Thanks tempdoug thanked for this post
    Likes tempdoug, Chicken Hawk liked this post
    18,832
    nd
    3,305
    yep, what i thought, and i was just guessing, but still looking hard at the #4. steve does that 16 really hold. thats a glue where if theres a little gap it works, where the 4 is more for wicking in after the parts are set together if theres no gaps. heres a good data sheet on the 3.https://www.curbellplastics.com/Research-Solutions/Technical-Resources/Technical-Resources/Bonding-Acrylic-with-SCIGRIP-3-4-or-16 these are for welding(they call it, melting one into the other) moreso than gluing.
    nd
    3,305
  1. Drilling Lexan
    By NunavutPA-12 in forum Cafe Supercub
    Last Post: 06-29-2016, 01:40 PM
  2. Lexan for seaplane doors
    By algonquin in forum Modifications
    Last Post: 01-13-2016, 05:57 PM
  3. Plexi glass or lexan?
    By akmagnum150 in forum Cafe Supercub
    Last Post: 06-13-2010, 10:38 PM
