As I am moving into detailing some wind design aspects for my plane, I am still in a quandary about locating good landing lights.
Clearly the size and packaging of useful lights has been changing and will continue to do so before I lock down my design but I have unknowns to work with.
I will at times be landing in a small field with trees lining the approach, the field is open. This happens to be a one way landing area with a hill on the other end so each approach will be a one shot deal.
My LE will have retracting slats, Handley Page style on the mid and outer wing. The inner 4' is, at this time not slatted. This could change should I be talked into it.
I plan on utilizing Wig Wag lights on the LE as well.
I would like opinions about landing lights being 3 to 4' outboard of the fuse which might get reflected by the prop? I know an incandescent would but are the LEDs less prone to that with the more controlled beam as I see from the new flashlights we have?
Or should I get the lights further out on the wing. This would require spacing between inner and outer slats. Or all the way out into the tips.
I do see lights under the belly being used, how are these working for those with them?
Thoughts?
Thoughts?
