Results 1 to 21 of 21
Thread: Fabing Piper(ish) Rudder / Elevator Ribs
    May 2014
    73
    I remember (?) seeing some posts of the process of fab'ing the ribs for the elevator/rudder but can't seem to find them. (Olibuilt? Was that you?)
    If not already obvious, I am curious from the experimental fabrication point of view, not a legality/morality/usefulness/"you will shoot your eye out" point of view.
    Any links/tips/hints/etc would be greatly appreciated.
    nd
    3,360
    ever consider making them airfoil shape?
    10,597
    I think I would bend the slight edges. Then press a die made of Corian into a rubber sheet. Then slide it off die. You must back up the corian with something like hard wood or thick aluminum or it will crack
    Other approach do edges slightly on bar folder. Then use press brake for the inner bends. Might have trouble on the small ends using this approach
    10,597
    https://m.youtube.com/watch?v=KTbgoWdb5d8
    10,597
    https://m.youtube.com/watch?v=LBtmkfSJhwQ
    May 2014
    73
    I was considering that for the horizontal stab ala Zenith and lesser so Bearhawk.
    Building them straight seemed to be a bit of a challenge without tool dies for the brake, so I was going to start there then work towards an airfoil shape.
    May 2014
    73
    Thanks for the video links. I never considered attempting a rubber hydro-ish-form for this, but will go watch and learn!
    Marty57's Avatar
    Jan 2005
    Nipomo, Ca
    1,384
    I made my own. Each rib is different by length. They were easy to cut on the angles and form the "U" channel needed. The 15 degree bevel in the rib to protect the fabric was done with block of wood formed to match each rob and bent with a rubber mallet; surprisingly easy. Here's a link to my website that shows how I did it. http://www.marty2plus2.com/past-post...y-feehans.html
    Marty
    N367PS
    www.marty2plus2.com
    Thanks motosix thanked for this post
    Olibuilt's Avatar
    Nov 2009
    Montreal, Canada
    821
    I've done it on a regular finger brake. I didn't need any forming block or rubber mallet.
    Started with the 2 edge bend, then the 2 90 degrees.
    Marty57's Avatar
    Jan 2005
    Nipomo, Ca
    1,384
    My bender won't make the 1/8" edge bend; too small to grab. If you do the edge bend first, how do you do the second bend without flattening the first bend?
    Marty
    N367PS
    www.marty2plus2.com
    RVBottomly's Avatar
    Sep 2017
    607
    Quote Originally Posted by Marty57 View Post
    Marty
    I remember using some bar stock between the finger and the part to bend so it wouldn't flatten the edge.
    But it was easier to cut oversize so you could clamp down more for the edge bend, then trim down.
    Sent from my SM-J320V using SuperCub.Org mobile app
    don
    717
    Those ribes are pain to fab. I welded in 3/8 ×.035 in place of those ribes on the elevators and rudder. Powder coated then epoxied 1/2" hard balsa. Sanded to shape. Epoxie varnish, then cover. Been there 12 years and hasn't rotted away yet!. You are building experimental. Those plans are someone elses idea. Experiment!
    May 2014
    73
    Quote Originally Posted by don d View Post
    I was considering taking some .020" 4130 tube, cutting a shallow V down the seam to allow me to make a very slight cone, then welding the seam and ends to the different sized main tubes. Besides being much easier to fab, it seemed like it would already be round so it doesn't cut into the fabric. I thought I was being all sorts of creative...
    Are you saying you just welded in tube then used balsa to make the transitions smoother? Genius. Biplanes do that sort of thing all over the place so I should have thought of it myself!
    May 2014
    73
    Quote Originally Posted by Olibuilt View Post
    Those must be really narrow fingers on that brake to be able to do those bends??
    You make everything look easy with the fab on your airplane, so I shouldn't be surprised you didn't have any trouble with this part.
    Cub junkie's Avatar
    My Moms basement
    2,066
    If you have access to a regular bending brake making those Piper style elevator/rudder ribs is easy. The challenge is the narrow trailing edge area. When you bend them into a "C" channel the 3/8" trailing edge will deform on a standard leaf. No problem as you can reshape the 3/8" trailing edge part of the rib with some flat bill sheet metal seam pliers. If you use a standard brake then make sure the leaf is set back enough for a acceptable bend radius. I use 20 ga. mild steel for these. Easy to form and cheap enough to make mistakes with for a learning curve. No need to overthink this part, no elaborate tooling needed.
    May 2014
    73
    Quote Originally Posted by Cub junkie View Post
    Thanks, I appreciate the details.
    I have a small bending brake, but not one wide enough to do these parts...
    RVBottomly's Avatar
    Sep 2017
    607
    That's what I was thinking. These were the first parts I made on my project some 2 years ago. I can't remember having any particular trouble. I used a basic bending brake and 20 ga. mild steel too. I think I messed up a couple pieces at first until I got the hang of it.
    I do remember using 1/4 square stock to offset the fingers a few times to preserve the little oblique edge bend. You jogged my memory because I later just shaped them up using some seam pliers I had from an aluminum roofing job.
    May 2003
    127
    The easiest way I have seen, is to use two pieces of Piper "C" Channel per rib. You know, the the material the bird cage is made from. Notch the channel to fit the top and bottom at the leading edge. At the trailing edge, notch and and taper the channel sides to fit the smaller tube. Do not weld, but Braze the channel to the tubes. Fast, light and easy.
    nd
    3,360
    what does jay at javron get for them? even if your set on making then yourself, just wondering?
    Mar 2016
    1,060
    Quote Originally Posted by ulpilot View Post
    That is what I intend to use for my rudder and elevators. The C channel can overlap it's mate as an option to tapering the small end.
    Cub junkie's Avatar
    My Moms basement
    2,066
    I don't dispute doing your way by any means. The downside is unless you get a smokin' deal on the tubing then 4130 tube in any diameter is 3 plus bucks a foot anymore. 20 ga mild steel sheet stock is much cheaper. Piper channel ain't cheap either.
  1. Elevator & Rudder turnbuckle ??
    By supercub in forum Cafe Supercub
    Last Post: 12-03-2018, 08:19 PM
  2. RUDDER and ELEVATOR HINGES
    By C-YQK in forum Tips and Tricks
    Last Post: 03-07-2011, 07:45 AM
  3. Elevator and rudder bushings
    By teeweed in forum Super Cub Repair Facilities
    Last Post: 02-20-2006, 10:41 PM
