Results 1 to 24 of 24
Thread: Shared freight on spar blanks
    Charlie Longley's Avatar
    Jan 2008
    Arlington, WA
    592
    I am going to order a wood spar blank for a J-3 from Aircraft Spruce. If anyone wants to share freight to the Seattle area let me know. On a side note is Aircraft Spruce still the best source?
    Mar 2016
    1,056
    Do you not have any good specialty wood supplies near you? Over here I buy my "Good" wood from Condon lumber in NY state, I select the blanks so I get the grain I want and then order the mill cut which is an S3S cut as in 3 of the 4 sides are finished to my dimension.
    Thanks Charlie Longley thanked for this post
    RVBottomly's Avatar
    Sep 2017
    607
    Aircraft Spruce is a good source, but it might take a while. I waited several months from first inquiry last year for two sets of spruce spars.
    There is a mill in Port Angeles worth checking out. I forget the name but Marty got spars from them and tied them to the roof of his vehicle. Maybe also EdenSaw in Seattle, too. Sometimes they have a good sense of local suppliers.
    Vic
    Sent from my SM-J320V using SuperCub.Org mobile app
    Hardtailjohn's Avatar
    Marion, MT
    727
    You should be able to find some at one of the wooden boat supplies over there. I got a set for a J-3 from Big Sky Stearman, in Oregon, and they were great to deal with. You might also try Lyle Sindlinger at Spar-Craft in Tacoma.
    John
    3,429
    As mentioned above, Marty57 got good wood from a supplier on the Olympic Peninsula. Maybe check with him?
    Jan 2008
    Arlington, WA
    592
    Thanks for all of the advice. I am going to go with Aircraft Spruce. Let me know if anyone else wants to get in on the order.
    Oct 2010
    Lakeland, Fl
    111
    I have always found Wicks to have better quality wood than Spruce. But I would think being in the northwest you could find it locally before it got loaded on a boat to China.
    Apr 2009
    Coleman,Tx
    16
    Tried to order from Wicks last week and was told that they no longer sold any wood. Dang!
    flybynite's Avatar
    Oct 2004
    Eagan, Minnesota
    353
    Check with Edensaw in Port Townsend. (800) 745-3336. Ask for Mast and Spar grade sitka spruce. You will have to get your IA to sign it off as meeting aircraft grade for spars. This is the end of a piece I have 2" x6" X 24' long. free of knots, shake and pitch pockets. You do see a split along the grain line about midway. A forklift was pushing a bundle on the end and split it, turning it into an 18' piece.
ID:	45725 Click image for larger version.
    Wayne
    Jan 2008
    Arlington, WA
    592
    Quote Originally Posted by flybynite View Post
    Wayne
    Picture isn’t coming through for some reason. I am going to order from Spruce as this is a customers airplane. I’ll probably order an extra front and rear spar blank to have on hand.
    RVBottomly's Avatar
    Sep 2017
    607
    That's strange. They show up on my phone app but not on the computer for me.
    Vic
    10,593
    Quote Originally Posted by RVBottomly View Post
    Vic
    Same
    Jan 2008
    Arlington, WA
    592
    Vic
    I am on my iPad and can’t see them. No matter.
    9,568
    Make sure that they package them adequately. Years ago I bought two large spar blanks from Spruce. They arrived with dings in the surface. Fortunately I was able to work around the damage since the spars needed to be routed out in that damaged area. At the very least they should be covered with a layer of plywood. Mine was covered with cardboard.
    Better yet find out where their supplier is located and go pick them up yourself saving a double shipping.
    Thanks CharlieN, Charlie Longley thanked for this post
    Mar 2016
    1,056
    I saw the pictures on my puter mid day yesterday, they were gone by night time.
    flybynite's Avatar
    Oct 2004
    Eagan, Minnesota
    353
    Dunno what happened...
    I had done a copy/paste from google photos. Went back and did an upload from my computer.
    They should show up now
    2,796
    Check with Edensaw in Port Townsend. (800) 745-3336. Ask for Mast and Spar grade sitka spruce. You will have to get your IA to sign it off as meeting aircraft grade for spars. …..
    Edensaw is about 2 miles from Jefferson County airport, south of Pt Townsend.
    It'd be easy to get there from the airport if they had the correct material & you wanted to inspect it before buying.
    A guy named Kiwi owns the place (guess where he's from!),
    one of their salesmen (Sam) is married to the owner of the airport café here.
    They also have a place in Seattle or Tacoma but I think it's just a warehouse.
    Jan 2008
    Arlington, WA
    592
    Surprisingly the spars have been shipped from Spruce. I called Edensaw a few days ago as a backup. Still waiting on a return call......
    Jul 2010
    Elizabeth, WV
    541
    Rainbow Ron in Moses Lake sells wood spars for Aeroncas. Does he sell Piper spars too?
    Jan 2008
    Arlington, WA
    592
    Quote Originally Posted by N86250 View Post
    I am pretty sure he buys them from Edensaw.
    Jul 2010
    Elizabeth, WV
    541
    I didn't know where he got them from his are ready to install.
    Jan 2008
    Arlington, WA
    592
    Right I am pretty sure that he doesn’t do J-3 spars.
    Jan 2008
    Arlington, WA
    592
    I received 3 spar blanks from Aircraft Spruce today in excellent condition. Around three weeks after I ordered them. Freight was less then $300.
    Likes flybynite liked this post
    2,796
    I talked to Sam from Edensaw yesterday, told him your call was never returned.
    "Hmmm.....tell him to call again". FWIW.
    He did tell me that they do handle aircraft spar-quality spruce, rattled off the spec to me (10% slope something...),
    and told me that most of that material originates from Vancouver Island.
  1. J-3/Wag Aero Wing. Wood spar vs metal spar differences.
    By iflyforpie in forum Super Cub Sick Bay
    Last Post: 10-27-2013, 10:22 PM
  2. Supercub freight
    By Zk Boy in forum Cafe Supercub
    Last Post: 11-14-2010, 12:06 PM
  3. Spar Blanks
    By wirsig in forum Experimental Cubs
    Last Post: 10-14-2008, 10:40 AM
