Results 1 to 21 of 21
Thread: O540 in a Super Cub
    Charlie Longley's Avatar
    Jan 2008
    Arlington, WA
    544
    O540 in a Super Cub
    Has anyone done it? If so how practical was it?
    2,688
    Seems like once years ago at the Arlington fly-in I saw a 540 on an exp SC from down around Sandy Oregon.
    Likes bush4 liked this post
    4,690
    https://www.supercub.org/forum/archi...p/t-36585.html
    https://www.supercub.org/forum/archi...p/t-48087.html
    What’s the HP output of an O-540? 235? You can do that with a 390 at 2/3 the weight, and that’ll be hard enough to balance on a standard length Cub.
    Jan 2008
    Arlington, WA
    544
    Thanks for the links! I like the idea of a 6 cylinders since they tend to run smoother. Some of the O540’s produce 260 HP. I would only consider a fixed pitch prop for weight.
    PerryB's Avatar
    Aug 2007
    Northern Calif.
    1,823
    There was one featured in one of the magazines (can't remember if it was AOPA or Flying) several years ago. Maybe even 15-20 years. I think it was black and used as a glider tug. I remember the owner said he had to watch the climb angle due to fuel starvation if it got too steep.
    Mar 2015
    221
    I flew one that was done years ago, was for sale so tried it out. Believe done originally in Oregon, but was in Kentucky at the time.
    Did not have the cub feel, was pretty heavy, smooth and lots of power, but just too heavy and felt too different than regular cub to me, so I passed on it. Just heavy on controls and felt that way in most respects. No acceleration you would expect with the power, weight was the key.
    Mar 2016
    952
    I would move the wing forward to balance the plane out. That alone would help allot with the feel of the plane. Then if you chose to run a controllable prop you get all the power it could make quite a workhorse.
    Not having really looked into it the upper part of the firewall could come back some to tuck the engine in as well.
    Jan 2004
    Rimouski,Quebec
    140
    Mike Patey scrappy https://youtu.be/stkvTQ1lCSw
    Olibuilt's Avatar
    Nov 2009
    Montreal, Canada
    813
    300 HP IO-520 C originally from Beech Baron
    TurboBeaver's Avatar
    Jun 2009
    Northern Maine
    708
    https://youtu.be/ZD1oz_3GaW8
    Watch this 300hp one fly.....
    4,690
    Not very impressive. That's surprising.
    Likes cubflier liked this post
    AkPA/18's Avatar
    Feb 2003
    Big Lake Ak
    650
    Might not be fair to judge the airplane on that take off. I don't think flaps were even used. Didn't look like he tried too hard.
    http://thrustline.com/
    Likes cubflier, Olibuilt, cubpilot2 liked this post
    Aug 2002
    Talkeetna Alaska
    262
    No flaps + poor float technique.
    Likes AkPA/18 liked this post
    Olibuilt's Avatar
    Nov 2009
    Montreal, Canada
    813
    That was his first flight...
    Getting better after a little practice:
    9,459
    Have you considered the Continental IO-360K? It is rated at 195 hp in the Hawk XP but is allowed up to 210 hp with the proper prop.
    4,690
    All that weight on the nose? watching stall tests would be more telling than takeoffs. I have a big motor CG riddle with a 390 and my plane’s airframe is extended. I can’t imagine a 540 being useful. Heck, lots of guys hesitate to put 360s on for fear of nose heaviness. PA-12 long mounts demonstrate that as well. CG is critical for a well behaved airplane. What do these big 6 cylinder Cubs add for ballast?
    Cub junkie's Avatar
    My Moms basement
    2,063
    If it was a viable engine choice for a cub they would be everywhere.
    Likes bowenjo liked this post
    4,690
    Every kid who ever played on a see-saw understands CG. Funny how as pilots we forget the lessons.
    Thanks gdafoe thanked for this post
    Dec 2004
    Inkom, Idaho
    1,365
    On a much smaller scale.... I used a Subaru conversion in my first S-7, about 40 pounds heavier then the Rotax I used in my current. It worked great, and was totally reliable for 1300 hours, until I sold it. BUT, even ballasted out (13 pounds of lead in the tail cone, not to mention aft mounted battery,tool kit, and all the other tricks to get the CG aft) it still only flew nearly as good as my new one when i was carrying a passenger or lots of baggage. Yes it was 15 more horsepower then the 80 horse Rotaxs back then (before the 100 hp version came along) but it taught me a lot of the effects of extra weight in the nose, even when CG corrected on paper to make it balance out.
    At least they used an appropriate yard crane to handle that engine! That got a chuckle out of this crane operator/lighter is better guy.
    fobjob's Avatar
    Aug 2002
    Salt Lake City, Utah
    2,056
    Met a guy at Minem lodge (way back when) who flew one in. Said it wasn’t really worth it.
    PerryB's Avatar
    Aug 2007
    Northern Calif.
    1,823
    I think it would fly like a a crowbar. Makes me recall watching a 600 Stearman land at an airshow years ago. He appeared to come over the fence with the stick all the way back and flare with the throttle.
  1. When Is a Super Cub Not a Super Cub...Challenges of Diversity
    By WindOnHisNose in forum Medical Matters
    Last Post: 03-13-2018, 02:37 PM
  2. Replies: 8
    Last Post: 07-14-2015, 01:06 AM
  3. Replies: 1
    Last Post: 06-15-2015, 10:43 PM
  4. Super Cruiser Elevator/stick/system/ is super Cub type
    By Fortysix12 in forum Cafe Supercub
    Last Post: 01-14-2012, 10:07 AM
  5. Super Cub Advertising at the Super Bowl
    By Bob Breeden in forum Cafe Supercub
    Last Post: 02-19-2011, 09:53 AM
