Results 1 to 10 of 10
Thread: 0-360 with Pawnee prop
    Colorguns's Avatar
    Dec 2013
    Bloomfield NY
    337
    Looking to put a p235-8443 prop on a -12 with 0-360.
    How will it preform over a Borer? Any thoughts? Lose about 10# off nose over a Borer prop.
    9,469
    Doug,
    I know that the folks in Alaska have used this prop for years with no issues. However since you live in NY you may have difficulties with the approval. Look at NOTE.9 on the Type Certificate: http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgMakeModel.nsf/0/3c9ce4689ef4ac398625726d006193be/$FILE/P12EA.pdf
    There is a maximum approved 78" diameter vibration limit on the 0-360.
    Colorguns's Avatar
    Dec 2013
    Bloomfield NY
    337
    N1PA.
    I have a FA 337 for the installation that has been run on for 20 years on the engine.
    Also the Borer is a 82” prop but 10# heavier.
    really wondering is there a performance increase with that prop other than 10# loss on nose.
    From experience in the field which is probably from AK that would really know.
    Doug
    9,469
    This is the "Borer" prop.
    http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgMakeModel.nsf/0/bea3a1655efbdf3486257666004a73fe/$FILE/P-857.pdf
    I do not see a significant difference in weights.
    May 2017
    484
    Given the diameter limit on the prop TCDS, an inspector, DAR, or DER would be overstepping their authority giving an approval for that prop on a 160 hp engine. Once done, it can’t be undone except by AD, but the person approving it could be in big trouble.
    18,832
    Do a search, some old threads on the Pawnee prop here as I remember.
    Colorguns's Avatar
    Dec 2013
    Bloomfield NY
    337
    Steve. Doing it, thanks for the direction
    Doug
    18,832
    Thanks Colorguns thanked for this post
    10,501
    we used to get them approved, quite a few running around here still
    what's this weight savings you mention???? I don't remember a big difference?
    edit: I think you mean it's lighter than the PADDLE PROP, not the borer 82"
    Dave Calkins's Avatar
    Jul 2002
    Anchorage, Alaska
    5,388
    That prop pitched to 45 inches on a strong O-360 pulls really hard, AND gets 104 mph cruise on a friends widebody EXP -18 with extended wings and 31’s. He throttles wwwaaaaaayyyy back to not outrun the stock supercubs when flying alongside friends.
    Likes Colorguns liked this post
  1. Pawnee Prop
    By cubdriver55 in forum Modifications
    Last Post: 07-03-2010, 12:50 PM
  2. Pawnee Prop.
    By jon in forum Modifications
    Last Post: 06-20-2008, 12:41 PM
