Results 1 to 30 of 30
Thread: 2" OD Aluminum Y fitting
    Meanwhile,...
    5,359
    I'm on a quest.
    I need a (one) 2" OD aluminum tubing Y fitting for a heater experiment anyone know where I can get just one or two?
    Kirby
    10,399
    I'm on a quest.
    Kirby
    Wag has them
    Meanwhile,...
    5,359
    Glen,
    My bad, I should have better described it. I'm looking for a symmetric Y so flow (would be flowing up in this context) will split evenly to the two branches and discharge at the same angle from the main leg.
    Kirby
    Farmboy's Avatar
    Jan 2016
    Glens Falls, NY
    2,545
    Kirby if you find one let me know. I looked for the same a few years back and all I found was plastic. After a number of heat cycles I discovered my heater output was greater than I envisioned, and the reason they use aluminum. Never bothered to fabricate one, but that was the next direction.
    pb
    10,399
    I used the type I posted in my J4 heat 10 years ago so that heat came out under panel in front of both sticks. The drag inside the scat tubing must balance it out because both deliver the same amount of heat
    4,280
    I have the one Glenn posted and a scat house hooked up the rear torque tube. The heater no longer melts one foot with the y attached
    4,280
    https://www.supercub.org/forum/showt...-heat-vent-mod
    Meanwhile,...
    5,359
    Close but no cigar, I’m working on the next great evolution...
    11,739
    Atlee has them as part of their defrost kit. Not sure if heíd sell separate. http://www.fadodge.com/universal-defroster-kit/
    11,739
    Maybe here?? https://www.summitracing.com/parts/sum-991104/
    10,399
    Always ready to learn even if the new and improved is coming from Oklahoma, does it even snow there? I thought you guys kept water in your bird baths year-round?
    Thanks irishfield thanked for this post
    irishfield's Avatar
    Feb 2003
    2,998
    I have a Tee...
    akskibum's Avatar
    Dec 2011
    Anchorage Fairbanks
    55
    Atlee has them as part of their defrost kit. Not sure if he’d sell separate.
    Atlee modifies their cub stuff for my Tern and doesn't make me buy the extra parts I don't need.
    nd
    3,717
    buy some 2 inch tubing, and find a guy that tig welds.
    20,375
    I can make you one, I might have one in my box of SCAT hose parts.
    10,399
    This works almost to good
    nd
    3,717
    glenn, ive made up my mind im going to do one like yours, but where that bottom piece can just slide down into a couple of grooves. got to make the bracket. for easy in easy out. even the top tee just going to make out of 2 inch aluminum.
    20,375
    Kirby, will this work?
    10,399
    First attach this to cabin side of heat box
    The right side of this Y has a belled end that will slip offer first fitting, screw it on or a hose clamp works
    Or this one will also slip over first fitting or other 2 outlets of Y
    First 2 fitting were from Wag, last one from ACS
    When I first mounted the heat up under panel I did a single outlet in front of the stick, it was so hot ( even at zero) I had to wear a glove on my stick hand, changed it to 2 outlets
    Thanks OLDCROWE thanked for this post
    Meanwhile,...
    5,359
    Yes!
    SteveE's Avatar
    Feb 2006
    Jenks, OK
    4,246
    Yes!
    $500
    Likes Tgskillskill liked this post
    20,375
    Quote Originally Posted by SteveE View Post
    $500
    For you it would be $600 or what i charged you to fix the JB Weld mess on the one you loaned me.
    Likes mike mcs repair, TurboBeaver liked this post
    CamTom12's Avatar
    Jul 2015
    Huntsville, AL
    782
    I'm on a quest.
    Kirby
    Kirby, I think I have an extra one in the hangar from an old experiment. Send me your mailing address and Iíll ship you mine. I canít return it and itís taking up space.
    nd
    3,717
    putting one of these down at the cab heat exit at the bottom of the V would even help to get the air to go up and around. just need to point it up at maybe a 45 from the floorboards.
    Meanwhile,...
    5,359
    I run a scat hose off of a diffuser at the heat box and I want to use a Y as a splitter on the downstream end to send warmth back seat towards each side and away from the master cylinders and other stuff.
    20,375
    I got stuck in the back seat on the way to your flyin and had the SCAT hose run under the seat and hook on the seat pocket. It was to hot to hold and just kept part of my warm until I looked it back under the seat pointing forward just below the seat base. It evened out the heat throughout the entire cockpit.
    Likes mike mcs repair, JDWilliams liked this post
    4,280
    This evens out the heat in the front pretty good and the long scat can be put in your jacket when you donít have a back seater.
    CamTom12's Avatar
    Jul 2015
    Huntsville, AL
    782
    Thatís the same fitting I have laying around. Kirby, send me your address!
    nd
    3,717
    This evens out the heat in the front pretty good and the long scat can be put in your jacket when you don’t have a back seater.
    dosent your stick get hot?
    11,739
    On another tread here that I canít find now , there was a place that made scat with doubled ends... I did an experiment to see if I could do it. I used silicone 2 part liquid for mold making to glue the piece on. It worked. Then I got thinking I bet you can do the same to just make the hose y joint without the aluminum. Still need to test. But Iím sure it will work after first test.
  1. Replies: 9
    Last Post: 12-18-2015, 12:48 PM
  2. Replies: 15
    Last Post: 12-13-2015, 11:03 AM
  3. Replies: 1
    Last Post: 10-13-2014, 06:06 PM
  4. Is aluminum AN fitting weldable
    By Pete Miller in forum Member to Member
    Last Post: 04-03-2007, 09:08 PM
