How are you moving the plane on floats off the grass runway to where you're going to lift the plane? How are you lifting the plane?
- use a spreader bar if you're lifting from the wing roots.
- get all your tools and parts assembled before you start. While the plane is hanging isn't the time to be looking for the correct bolts.
- consider new bolts for all the parts in the wheel gear.
- have all your wheel bearings greased before you start.
- have several large punches and "bullets" to help line up fittings.
- attach the tail wheel before lifting or removing the floats.
- depending on how you lift the plane, give some thought on how it's going to balance. You may need to remove/add weight from baggage area or add some up front.
- tie a rope to wing tie down rings or tail so you can control the plane if it wants to swing around.
- move prop to horizontal.
I'm sure others can add to this.
Do do you fly skis in NZ? If so and you attach front ski cable to front gear fitting, use a longer bolt and have threads/washers/nut facing forward. Add additional washer/spacers.
Jim
Gentle patience instead of brute force. Move the airplane or floats around to unbind bolts rather driving them out with a punch, your plane will thank you. Remove a bolt, replace it with a screwdriver or punch, Get them all out and replaced, then while someone stabilizes the plane you can easily pull the screwdrivers by hand, nothing gets twisted. Only loosen one set of drag wires ( left or right) this gives you the wiggle/looseness you need and now you don't have to start at ground zero when you go to install them next season, you're already halfway rigged.
