CranelakeMN
Crane Lake, Minnesota
Looking for suggestions to run new wire from TYPE AA7 Mag Switch to Magneto's. Shielded wire has been suggested... looking for wire size, single strand or braided etc... etc...
Thx.
Thx.
And never bundle P-leads with any other wires.
20 gauge, single conductor, shielded wire. Use Sumitomo solder sleeves to attach a 20 gauge jumper wire to the shield at both ends of the wire. At the switch, attach the center conductor of the right hand wire to the terminal marked 'right' and the jumper to the terminal marked 'ground'. At the right hand mag, attach the center conductor of that same wire to the P=lead terminal and the jumper to the mag body. Do all the same steps for the left hand...
20 gauge, single conductor, shielded wire. Use Sumitomo solder sleeves to attach a 20 gauge jumper wire to the shield at both ends of the wire. At the switch, attach the center conductor of the right hand wire to the terminal marked 'right' and the jumper to the terminal marked 'ground'. At the right hand mag, attach the center conductor of that same wire to the P=lead terminal and the jumper to the mag body. Do all the same steps for the left hand wire.
The shield is also grounded at the magnetos in the Cessna 180/185 diagrams. Both ends of each P lead shield are grounded.It seems like grounding only at the mag (as you indicate above) is the way to do it, but what if the wiring diagram is different? For example, the Cessna 180/185 diagrams show the p-lead grounds attaching to the switch GRD terminal, which then is connected to airframe ground under the panel.
Chris
