kevinbarton1
San Antonio, TX
Has anyone put the 160 HP STC on and how did you mount the oil cooler. When I try to use the mounting bracketry it contacts the starter battery post.
I completely re-did mine also. I did it a little differently than Craig, but similar idea. Craig, next time I see you we should compare, just for grins.
Never had good service out of PM/LS starters on 180 hp engines. Have had excellent service out of them on 150/160s. Great service with the NLs on all engines and have installed a couple of the XLT starters and will see how the last.Anyone been having problems with the Skytech starters? Have heard mixed reviews lately. Thanks for any info
Their STC permits moving the oil cooler, without an additional STC. It's not required. I have Plane Power and front oil cooler.The problem is PlanePower STC requires you to move the oil cooler.
