Results 1 to 10 of 10
Thread: Seper Cub vs Cub - fuselage
    Oct 2019
    5
    Hi boys,
    I am big fan of aircrafts, models from Czech Rep
    I for example do master for resin kits models in 1/72
    I like fly on old machines, and...
    I flown on L4 a few years ago
    and
    I flown last week on L18C (ex USAF, anf Luftwafe)
    I have one question about fuselage
    I did sudy many many drawing, but I still not know correct diferent
    - 1st have Cub and Super Cub the same breadth ? in not - what many cm is diferent in cocpit ?
    - 2nd have fuselage the same side view ?
    Drawing see - fuselages the same from instrument panel
    ¨but
    I think that Super Cub is "slightly bloated"
    I would like truth from experts
    Thanks Martin Decarli
    Czech Republic
    18,755
    J3, PA11 and the Super Cub PA18 are the same dimensions. The fit in the same fuselage jig with an adapter for the front spar fittings. The seat is oin a different location. I believe the instrument panel is in about the same place.
    Oct 2019
    5
    Thank Steve
    Think You that really is the same width fuselage in cocpit place???
    Thanks Martin
    18,755
    Yes, I have all the drawings and the jig and have repaired quite a few J3, PA11 and PA18 fuselages. Width is identical.
    WhiskeyMike's Avatar
    West Boxford MA
    881
    I have bolted many PA-18 engine mounts directly on to J-3 fuselages to make Restricted category 135HP and 150 J-3's. Same width, minus some braces; and the bird cage differs. I've actually had people tell me the J-3 birdcage has some strength advantages, but of course you have the wing spars slightly blocking your view - and they can be safety hazard for your head. With the fad for sitting super high in the seats with big cushions that could be a problem, but I always preferred to be more centered in the fuselage and have a better grip on the stick. You tend to hold on tight when you're terrified.
    Likes RaisedByWolves, Brandsman liked this post
    Oct 2019
    5
ID:	45210Click image for larger version.
ID:	45211Click image for larger version.
ID:	45212Click image for larger version.
Name:	Já Piper.jpg
    Likes L18C-95 liked this post
    Oct 2019
    5
    Super Cub (L18C ex Luftwaffe) over Stutgart /Germany)
    and replica L4H over Prague
    Thank You for infou about fuselage !!!
    I really believed that L18 is wider....
    PS Yes, I know, bird cage is diferent...
    Oct 2008
    Johannesburg, South Africa
    53
    Interesting replies - I did not know that the J-3 and PA-18 used the same jig and I always assumed that the PA-18 fuselage was way stronger than a J-3. What dictates gross weight - the fuselage or the wings? I expect the undercarriage also has heavier tubing in the 18? It’s interesting to me because the J-3 gross cannot be increased over 1320 lbs while 18s come in 1500 and 1750 flavors and can be upped to 2000 plus...
    Margaret Thatcher
    Oct 2019
    5
    Yes Brandsman - many my friend thit to today that fuselage from 18 is bigger.....
    PS All plastic kits in world also have fuselage wider
    PS II I did master for J3 1/72 plastic kits and I did fusselage
    [COLOR=rgba(0, 0, 0, 0.87)]slightly narrower Click image for larger version.
Name:	J 3 2.jpg
ID:	45219Click image for larger version.
Name:	J 3 4.jpg
    18,755
    The dimensions are the same. The PA18 has more tubing and heavier duty gear/strut attach fittings. The landing gear on a PA18 is the same part number as the higher groww weigh J3.
  1. Replies: 30
    Last Post: 09-09-2018, 12:16 AM
  2. J3 fuselage jig
    By Idaho180 in forum Member to Member
    Last Post: 01-11-2018, 12:47 PM
  3. Fuselage Jig
    By robertc in forum Cafe Supercub
    Last Post: 07-12-2017, 06:59 AM
  4. New fuselage or no?
    By bgriffel in forum Super Cub Sick Bay
    Last Post: 07-17-2013, 06:31 AM
