Results 1 to 13 of 13
Thread: Slats vs Slots pros/cons
    Nov 2010
    64
    What are the pros and cons of the hinged leading edge slats vs the fixed leading slots?
    11,527
    Patey did a discussion on that in the Draco build youtube videos.....
    11,527
    maybe this video?
    Wolf Lake, AK
    5,644
    Exp vs certified. How many exp guys choose slots? How many slot wings have beat slats in contests?
    Personally I think Pstol flaps are the priority. Slats follow.
    Likes DENNY, J5Ron liked this post
    Nov 2010
    64
    Good point and that is exactly the info I am seeking. Who is buying slats vs slots and why?
    Wolf Lake, AK
    5,644
    Me? Slats W/Keller flaps. Why? Because I haven't seen anything the comes close to the performance that slats and Pstol flaps offer.
    Likes flyrite liked this post
    2,178
    Dakota Cub has wings with slots for certified aircraft, so far no certified slats. Both will hurt top end airspeed. Stewart, when you get the Wildcat back up it would be nice to do top speed with and without the slats. I have heard everything from 3-7 mph loss with them. I am sure slot rigging and balance has something to do with it. I will be happy to buy the beer if you are interested.
    Valdez, Alaska
    650
    Exp Super wide Cub.
    0-320 170+hp
    31” Tires, 3” gear with TK-1 shocks
    Round tips
    Catto 84x37
    Carbon Fiber Slats
    Before Slats I would cruise 92mph @2400
    With Slats I cruise 86-87mph @2400
    Slats are adjusted with bottom of slat cuff about 1” below bottom of wing...
    Likes flyrite, DENNY liked this post
    10,677
    Quote Originally Posted by cook11 View Post
    Fixed leading edge slats have a fixed rather high drag component.
    A well designed hinged slat will blend into the leading edge at cruise speeds without a drag penalty.
    Likes Amy, mike mcs repair, moneyburner liked this post
    20,189
    I have seen a speed reduction in slats but we have a lot of time with stock wings vs the Dakota Cub slotted wing in my wife's Tri-Pacer and no difference in cruise speed what so ever. Bill Duncan thought the slot on his Maule was costing him cruise speed but he never taped it up to see.
    Likes Amy, DENNY liked this post
    10,677
    The Globe Swift has a fixed slot built into the wing planform for enhanced aileron control at low speeds. There is an STC to cover this slot which claims to increase the cruise speed indicating reduced drag with the cover installed.
    Likes DENNY, RVBottomly liked this post
    2,178
    Steve
    Was the slotted wing square? That should make it a bit faster than the stock round tip wing. Combine that with a slot and it should be a wash.
    Wolf Lake, AK
    5,644
    Honestly I’m not concerned with top speed or drag from slats. After talking to several experienced slat guys I used Backcountry’s advice and mounted my slats flush with the bottom of the wing. With that my plane cruises at 100 mph and stalls under 20 mph. That airspeed range works for me. My Cub wasn’t built for speed but it turns out its a fairly fast Cub that also flies slow. While the speed impact of adding slats isn’t important to me I’ll get before-after data the easy way. My nephew just bought a new SQ build that doesn’t have slats. When he gets it home he’ll be adding them. I’ll get numbers from him.
    My slat hangers are attached to the wing using nut plates rather than PK screws. The purpose was to allow me to make different hangers to reposition the slats lower relative to the bottom of the wing. Since I’ve lost a year to the engine problems my interest in that experiment is fading. I just want to fly it. My new motor should make 15+ more hp than the old one. I’m more interested in that than fiddling with the wing.
  1. SuperStol VS Supercub Pros/Cons...Im looking to buy
    By Backpacker in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 10-09-2019, 08:56 PM
  2. Airstrip Registration, Pros and Cons
    By Jacob Papp in forum Cafe Supercub
    Last Post: 08-13-2016, 06:00 AM
  3. Jackscrew Vs. Trim Tab Pros and cons?
    By pipercubnut in forum Modifications
    Last Post: 05-03-2010, 10:09 AM
  4. Widebody Pros and cons
    By Jeff in forum Cafe Supercub
    Last Post: 02-18-2007, 02:59 PM
