Page 1 of 2 12 LastLast
Results 1 to 40 of 45
Thread: Does your C180 cylinder baffle look like this?
    SJ's Avatar
    Jan 2002
    Kansas City, USA
    14,619
    #5 is my hottest cylinder - not by a lot, but enough that that is the one I focus on. The oil cooler is of course in front of it, and the extra little baffle on top. Does everybody else have that extra little baffle? It's a PPonk if that matters..
    4,693
    Yes. I believe it's a 185 part. I never had it with 470s.Click image for larger version.
    Thanks SJ thanked for this post
    SJ's Avatar
    Jan 2002
    Kansas City, USA
    14,619
    Thanks. Man I need to clean my plane!
    Sent from my Pixel using SuperCub.Org mobile app
    4,693
    My typical cruise temps.
    SJ's Avatar
    Jan 2002
    Kansas City, USA
    14,619
    Mine are very Oat sensitive. I usually keep the cylinders under 350, but at the expense of higher fuel burn in the summer.
    10,519
    I don't think that's a standard 185 part, but I've not flown every model year either.....
    Meanwhile,...
    5,051
    Airplanes IO520 conversion, on 180K, baffles installed by them.
    Unless I’m up high running peak #4 is hottest then it’s no. 5.
    Yesterday, coming back from Colorado at 11.5 / -1 OAT and running peak I had 1435 peak EGT and 345 CHT with 185 oil temp (Gill vent covers on) with all cylinders within 30 degrees EGT and 50 CHT
    4,693
    #5 cylinder baffle is part #1250134-1 or -2 for serial numbers 18502311 thru 18502392 and 18502825 and up respectively. I don't see such a part for the 180 but I didn't look very hard.
    I put mine on after Steve Knopp told me it would be a good idea since 185s use it. I didn't have a monitor back then. Now that I do I see no reason to change anything.
    180Marty's Avatar
    May 2004
    Paullina, Ia
    2,026
    I have a nose bowl like yours and my 470 cylinder looks like Kirby's. Looks like your engine is sagging a bit judging from the spinner and cowl position.
    supercub's Avatar
    Apr 2002
    799
    Might want to check your motor mounts, appears your engine is sagging some. Could be somewhat disrupting the air flow for proper cooling.
    Likes Delta Cub liked this post
    9,459
    sj, There is supposed to be a narrow baffle which goes between the oil cooler and the cylinder. Do you have one installed?
    SJ's Avatar
    Jan 2002
    Kansas City, USA
    14,619
    Yes, I have one installed, I was wondering if I was supposed. BTW, I have the anti-thrustline mod. That is why it looks like the engine is sagging... I'll have Pierce check his photo archive of when the engine was put in for comparison.
    9,459
    sj,
    I seem to recall there should be a large thick washer between the engine mount and the firewall at the lower bolts. I'd have to check the manual.
    SJ's Avatar
    Jan 2002
    Kansas City, USA
    14,619
    These are shots from the 2010 WAD, soon after the engine install (with rebuilt or new motor mount). Looks like the cowling has never lined up quite right with the spinner.
    Tim let me land at his house...
    2,692
    Curious if youre running the orginal 470A/J mount (with the vertical rubber isolators)?
    SJ's Avatar
    Jan 2002
    Kansas City, USA
    14,619
    It's a 520 case, not sure if it matters, I do think we used the original mount but would need to check the logs.
    Mar 2018
    69
    My #2 and #5 run the hottest. I also have that baffle on top of the #5 cylinder - I installed it when I did the IO470 upgrade.
    18,817
    It is the original engine mount with the orginal engine mount legs off the O-470 installed on the O-520 crancase used in the P-Ponk conversion. Baffles were new from Airforms with some tweaks recommended by Steve Knopp. I don't think the engine ever fit exactly in the center of the opening. This is when installed in 2008.
    18,817
    Pete is referring to these washers I think.
    SJ's Avatar
    Jan 2002
    Kansas City, USA
    14,619
    I remember the fun you had replacing that gascolator...
    Thanks!
    18,817
    Thanks!
    Wasn't that long after the engine change or am I thinking of the Super Cub?
    supilot's Avatar
    453
    I think I have a pretty similar setup SJ, but I don’t have that extra little baffle. Did airforms as well, with no modifications required minus blocking off a couple port holes not used on our early model configurations. Not sure why uploading from my iPhone rotated the pictures. 1955 180.
    Attachment 45153Click image for larger version.
ID:	45154Click image for larger version.
    behindpropellers's Avatar
    NE Ohio
    6,700
    Thanks!
    Oh that one is easy to get to. The one in the 206 is way up under the nose strut.
    520 in my 206 has that baffle in place. 550 in other 206 that I know of is missing that baffle. 550N in columbia does not have it. 470 in 1976 182 does not have it.
    SJ's Avatar
    Jan 2002
    Kansas City, USA
    14,619
    No, it was on this plane - and it was a while after. would not want to make it easy with the engine off an all...
    Thanks FLYERKODI thanked for this post
    2,692
    Mine is similar, except with a stock 470K.
    I had to repair a crack in the engine mount a couple years ago,
    the Lord rubbers were sagging in the extreme so I replaced them.
    I'm expecting to need to do an engine overhaul before too many more years go by,
    at which time I'm planning on installing a later model mount which uses the horizontal-ish rubbers.
    I think they hold up a lot better, plus based on an old service letter (SL180-1) I hope that arrangement will be a lot smoother.
    FWIW from the photos, SJ, it kinda looks like your engine might be sagging down a bit lower now,
    compared to Steve Pierce's photo from 2008 in post #8.
    Likes SJ liked this post
    18,817
    This is how I can tell how long ago things were now. He is bigger and taller than me. I miss that kid running around the hanger getting into stuff.
    Likes SJ, mike mcs repair, brown bear liked this post
    Meanwhile,...
    5,051
    Log book time and Lee Pierce growth rings, do not always appear to coincide.
    Oct 2019
    W. Colorado
    1
    This is a very common problem, and best fix is to use the Martin Aviation replacement baffle, ~$500. This cools #5 and #3. Call them for details 318-574-5855
    Jun 2008
    TN
    55
    1975 180J with Texas Skyways O-520
    2,692
    ….I'm planning on installing a later model mount which uses the horizontal-ish rubbers.
    I think they hold up a lot better, plus based on an old service letter (SL180-1) I hope that arrangement will be a lot smoother.....
    To elaborate a bit on my thread drift:
Name:	Cessna S.L.180-1.jpg
    SJ's Avatar
    Jan 2002
    Kansas City, USA
    14,619
    So I went down to look for saggy mounts... they don't look too saggy to me... click to enlarge.
ID:	45172Click image for larger version.
    NE Ohio
    6,700
    Mount looks great but is the saftey wire missing from that bolt
    3,376
    And type "A" screw in tinnerman nut.
    SJ's Avatar
    Jan 2002
    Kansas City, USA
    14,619
    They fall right out! I have a pile of tinnermans, just need to replace it I suppose...
    Meanwhile,...
    5,051
    From the looks inside the cowling your 180 is channeling its inner radial self.
    3,376
    SJ, I was just giving you a rash, because I know I read somewhere that Tinnerman nuts require type B screws, due to difference in thread pitch and very slight difference in root diameter between type A and type B. In my experience the type B screws seem to hold better.
    The Specification Chart part of this page https://www.aircraftspruce.com/catal...?clickkey=5485 indicates type B.
    However, page 68 in this pdf seems to permit either. https://spaenaur.com/wp-content/uplo...s-C67-C101.pdf
    So now I'm confused. Can you pros out there set me straight (with certainty, rather than just opinion)?
    Thanks windy thanked for this post
    Alex Clark's Avatar
    Feb 2004
    Life Long Alaskan
    3,144
    I do not have it on my P-Ponked 180
Name:	2008-12-31 155 (1280x778).jpg
    Oct 2017
    7
    I do have the baffle on my 1976 Pponk 180. And my #5 runs hot.
    4,693
    The three variables. Balance tube, induction, and fuel flow. But that said, I wonder if that baffle increases heat at #5 or reduces it.
    Mar 2018
    69
    There is a very old Cessna SB that calls for the addition of that #5 baffle for the IO470 to even out cooling.
  1. Engine Baffle
    By wpbrady in forum Cafe Supercub
    Last Post: 03-24-2012, 10:32 AM
  2. Oil Well Baffle on a C85 PA11
    By Ken Kennedy in forum Modifications
    Last Post: 03-04-2012, 10:14 PM
  3. Baffle interference
    By Ron B. in forum Super Cub Sick Bay
    Last Post: 04-21-2005, 10:09 PM
