Results 1 to 12 of 12
Thread: Elevator spring
    Jul 2019
    O’Fallon, MO
    25
    Elevator spring
    My supercub, which was rebuilt ground up in 1999, has a spring on the elevator which holds the elevator up above the horizontal stabilizer while in a resting state. This spring requires a lot of force for full forward and full aft stick, making it difficult to finesse aileron input while applying forward or aft stick. Is this spring tension normal for super cubs, or is it an aftermarket STC addition? Would spring tension be adjustable?
    My super cub requires an extreme amount of trimming in the pattern; with full flaps and full nose down trim, I still have to apply a fair bit of forward stick to maintain airspeed on final approach!
    10,668
    Spring is controlled by stabilizer position. Heavy cubs might do better without it. You can adjust cable length.
    Sep 2006
    Maynard,MA
    1,229
    I don't get why aft stick requires more force.Does it have 1 spring or 2 back there?
    Jul 2019
    O’Fallon, MO
    25
    I have not opened it up to view spring(s). The spring tension increases significantly the further stick is pushed or pulled.
    Jonnyo's Avatar
    May 2014
    Fairbanks, Ak
    130
    What is the purpose of the spring ?
    PerryB's Avatar
    Aug 2007
    Chico, CA
    1,885
    They were required to get the airplane to meet the pitch stability/ oscillation requirements for certification.
    Sep 2006
    Maynard,MA
    1,229
    You can see pictures of the spring and cable in the Javron cub post pictures.Look at the elevator control horn.
    I installed it for the purpose of relieving stick pressure at slow speeds.It should make up elevator easier but you say yours is harder both ways.I don't see how that can be.
    19,089
    Those pictures should help. I suspect something is not installed or rigged correctly.
    6,910
    I have flown Super Cubs with very weak springs. A sheer delight, not having to trim all the time. I am with Mike above.
    19,089
    The spring has nothing to do with having to trim the airplane in my opinion. My Super Cub only required trim for the load when leveled off and two turns of nose down trim when entering the pattern and pulling flaps. Installed the Thrustline mod and all I do is trim the load. Slow down in the pattern and have stick pressure until I pull flaps and then neutral. I think you have a rigging issue or something is installed wrong. I have flown to many Super Cubs that were like mine.
    9,969
    You'll find that pilots that cut their teeth on J3 don't like the spring on Pa11 or Pa18, J3 doesn't have a spring
    supercrow's Avatar
    Dec 2008
    326
    I never used the spring on any of mine. Just fine without it, even on oversize tailfeathers.
    Likes mike mcs repair, NunavutPA-12, Jonnyo liked this post
  1. Elevator Spring
    By Glidertow in forum Modifications
    Last Post: 10-05-2014, 10:30 AM
  2. Elevator Spring Tension
    By mgberry in forum Member to Member
    Last Post: 06-01-2012, 09:39 PM
  3. Elevator assist spring
    By eski in forum Cafe Supercub
    Last Post: 05-14-2009, 10:40 PM
  4. Spring loaded elevator
    By marinelubricants in forum Cafe Supercub
    Last Post: 05-06-2004, 11:36 AM
