Results 1 to 2 of 2
Thread: Wood wing varnish
    Jan 2019
    2
    Wood wing varnish
    Ready to assemble the WA j3 wing. Looking for advice on how to do the varnish job. Is there an better/easier way than small brush and lots of patience?
    Should I do the ribs before final assembly?
    RVBottomly's Avatar
    Sep 2017
    1,030
    Partly it depends on the varnish you are using. Is it epoxy-based?
    I think it would be important not to varnish any place you intend to use adhesives, like the spar/rib attachment points.
    FWIW, I've varnished and/or epoxy-varnished entire boat interiors in an afternoon. I plan to do my wing in similar amount of time--after assembly, although I'd probably put an application on areas under metal fittings prior to assembly.
  1. My 64 pound wood wing
    By Marty57 in forum Experimental Cubs
    Last Post: 09-11-2014, 11:40 PM
  2. New floorboards... Varnish or epoxy varnish..
    By bgriffel in forum Tips and Tricks
    Last Post: 06-12-2013, 11:17 AM
  3. Progress on my wood wing
    Last Post: 12-20-2012, 02:15 PM
  4. wood spar wing
    By donnuts in forum Member to Member
    Last Post: 10-15-2007, 11:31 AM
