Results 1 to 5 of 5
Thread: Millennium failure
    Jan 2017
    Utah/Alaska
    41
    Millennium failure
    I was asked to come look at a customer's airplane, they had a cylinder failure. This is on an o-300, but the jug is the same as the 0-200. C-90, and the c-85. Total time was 1400. Pilot landed safely. Compressions were good on the last annual. I dont think any routine inspection would have found this fatigue failure, the barrel actually broke and about 1.5" was still in the head. Since a lot of cub drivers use the small continentals, I thought I would pass this information along. I will be submitting a service difficulty report to the FAA. I hope no one else has to encounter this. TimClick image for larger version.
ID:	44477Click image for larger version.
ID:	44478Click image for larger version.
    4,560
    Lots of ADs on Millenniums regarding cracks. Not sure about that engine size but I'm familiar with my own.
    10,346
    Won’t show on normal compression check. Rings are above crack. The various ADs have yo do a soppy water check with piston BDC if I recall correctly. Thanks for sharing
    Jan 2017
    Utah/Alaska
    41
    Most if not all of the superior AD's were on big continental and lycomings...I have not seen one on the small continentals.
    Feb 2019
    19
    Inspecting a C85 with Millennium cylinders new in 2018 with 40 hours on them. Seeing some possible oil seeping from the barrel to head interface on two cylinders. One showing slightly more than the other, the other two look to be ok. The oil is not from the pushrod tubes or rocker covers. Will be doing a compression check and a soap test similar to the ECI AD to see if there is a problem with these cylinders.
  1. PA-18 engine failure
    By 747driver in forum Cafe Supercub
    Last Post: 06-21-2013, 02:50 PM
  2. 0320 cam failure
    By Jim Scarborough in forum Experimental Cubs
    Last Post: 10-04-2012, 04:17 PM
  3. Superior Millennium cylinders
    By PA-22/20-160 in forum Cafe Supercub
    Last Post: 04-25-2005, 09:37 PM
