Thanks Thanks:  0
Results 1 to 5 of 5
Thread: Wing extension/flaps
    Sep 2019
    1
    I ‘inherited’ a pa18 project. It has flaps with a clipped wing 28’. 0-290.
    Questions:
    1. What’s the possibility of extending the wing?
    2. Would it even be necessary with the flaps? I’m actually looking for stall speed specs.
    PerryB's Avatar
    Aug 2007
    Chico, CA
    1,985
    If I'm envisioning your wing correctly, you'd basically have to get new spars and a few new ribs, and rebuild to original configuration. I would definitely take it back out to stock span. Eight feet is a LOT of lost wing area. I don't see a clipped 18 doing much of anything very well.
    Likes flyrite, mike mcs repair liked this post
    2,106
    Did they change the strut attachment point? If so I would follow the above advice. If they have the stock strut attachment you should be able to add spar length as long as the splice is beyond the stock strut attachment point. Lots of bent spars laying around you could get 4-6 feet out of.
    10,487
    Which end of the wing was clipped, inboard or outboard? If it was the outboard, just splice on a new section of spar using Piper's approved spar splice method. If the inboard end, there will be a lot of work involved including changing the angle of the strut fitting on the fuselage along with new struts.
    Farmboy has a clipped wing Wag -18 which matches your description.
    19,911
    Sounds like a Clipper, Pacer or Tri-Pacer wing. Certified or experimental? Pictures?
  1. Fowler flaps on a cub wing?
    By eskimo77 in forum Experimental Cubs
    Last Post: 02-15-2015, 05:59 AM
  2. flaps on t-craft wing
    By sibbeston in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 09-28-2011, 11:07 AM
  3. PA-18 Flaps on PA-12 wing
    By Fido in forum Cafe Supercub
    Last Post: 05-27-2009, 07:38 PM
  4. Bi-Plane bottom wing flaps.
    By T.J. in forum Experimental Cubs
    Last Post: 02-21-2006, 12:10 PM
