Do they still sell these vents?
sj
Staff member
Northwest Arkansas
My plastic innards are broken... need to find a source.
I ordered them from Univair since they support the site - and they were cheaper!
sj
3521s work pretty well. 352s not as well. The smaller ones can't be closed so my airplane was a home for insects until I replaced them.
The hole diameter is critical to make them work well.
They flow a lot of air but they sometimes leak in the rain. They do pump some air.....
I tape mine closed in the winter.
They work great in the summer.
Same vent Cub Crafters uses in the sky light of their Carbon Cubs. Makes a lot of noise when you try to close it and it departs the airplane with part of the skylight. Always carry color coordinated duct tape. ;) I use a 3" hole saw in the drill press turned slow to drill the hole because, like noted above, the vents don't work well if the hole is wallowed out from a chattering hole saw.
