Page 2 of 2 FirstFirst 12
Results 41 to 53 of 53
Thread: Dead Stick!
  1. #41
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    1,597
    What's this "sink rate" thing about? You come down when the engine quits?! https://www.youtube.com/watch?v=8J9v433C0nM 5:00 in for the shutdown.
    Ha, no ridge with a good breeze blowing into it I'm guessing, lousy luck! I ridge soar with one notch of flaps, 45-55 mph, glide seems to be about 7-1, twice as good as my first few hang gliders anyway. Sink rate about 750 FPM. I like to think my time spent engine off will help in a real emergency dead stick, but who knows until it happens for real.
  2. #42
    3,111
    I assume that you have a 180? Eddie has a 185. Different gross weights. Also Eddie's flight test was done at less than maximum gross. I assume that Cessna's manual was based on maximum gross weight. This may account for the differences you are seeing.
    My question / comment is only about the POH best glide graph.
    I believe Eddie has a C180H.
    Different gross weight, correct.
    May be why it shows 85 mpg glide instead of 80.
    That's a pretty dramatic difference in glide ratio though.
  3. #43
    L18C-95's Avatar
    May 2011
    Oxford UK
    494
    The 185F POH shows 80 MPH on the chart
  4. #44
    3,111
    Can you post a scan or photo?
    Or give us a example--
    for example, Eddie's chart shows 20 miles of glide from 10,000'.
  5. #45
    10,212
    My A185F manual shows a ground distance from 10,000 feet of 13 nautical miles or 15 statute miles. The best glide speed varies dependent on gross weight. 3350#-75 knots, 2650#-67 knots and 1950#-58 knots
    For comparison, when on EDO 2960 floats the distance from 10,000 feet is 12.5 nautical miles. 3320#-75 kias, 2820#-69 kias and 2320#-63 kias.
    Interesting that when on EDO 2790 amphibs the difference is just the speeds and weights. 3265#-75 kias, 2865#-70 kias and 2465#-65 kias.
  6. #46
    L18C-95's Avatar
    May 2011
    Oxford UK
    494
    Dead Stick!
    1973 185F POH
  7. #47
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,622
    My plane is a 69 180H. The chart I posted is from a 68 180 POH.
  8. #48
    3,111
    The two 185 graphs are the same as mine.
    Maybe the one I have is from a 185?
    Can't recall who sent me the scan,
    as neither of the early 180 owners manuals I have (53 & 57)
    have any engine out / glide info or procedure at all.
    Like I said though- pretty drastic difference in glide ratio.
  9. #49
    Vermont
    318
    I used to think "dead stick" meant loss of propwash makes the stick kinda dead, but its really from when all props were wood. Years ago a Luscombe pilot rigged up a microswitch that touched a wire that went thru a tube and touched the back of the prop flange. The axial play was enough to trigger the sw when the power was pulled just below zero thrust. No risk dead stick practice.
    What's a go-around?
    Likes N86250 liked this post
  10. #50
    3,111
    The two 185 graphs are the same as mine. Maybe the one I have is from a 185? ....
    Looking at the little airplane in the graph,
    I see mine has a bigger (185-ish) dorsal.
    So I guess it is from a 185.
  11. #51
    10,212
    Starting in 1975 the 180s which had a seaplane kit had the larger 185 vertical tail. Without the seaplane kit they had the small tail.
  12. #52
    Farmboy's Avatar
    Jan 2016
    Glens Falls, NY
    2,388
    4000 feet probably seems pretty high (can't remember getting there) until you want to glide. Using the 185F chart that's about 6 miles without smiles. I'd guess that 6 miles is shorter than you may think.
    I've seen this before, from which I've always appreciated knowing that as long as I can glide better than 1:14, I've got a fighting chance:
    "A glide ratio of 20:1 might be appropriate for an Eagle riding the wind while a 1:14 ratio is similar to the glide capability of a brick."
    http://www.csgnetwork.com/glideratiocalc.html
    I like looking at the time factor. According to that calculator, at 500 AGL in a supercub in a stabilized 6:1 glide, you have 30 seconds before touchdown, depending on your choice of speed. I doubt a bush wheel equipped supercub would have much better than a 6-ish:1 ratio.
    Likes Colorguns liked this post
  13. #53
    Sep 2006
    Maynard,MA
    1,234
    Interesting technical discussion with some good information.I am curios though.How many still routinely fly closing the throttle abeam your proposed touchdown point and land the airplane?The bulk of my landings are done this way.
    Likes super stol liked this post
  1. Dead stick - not what you think!
    By clouds in forum Cafe Supercub
    Last Post: 08-03-2012, 11:59 AM
  2. Dead Stick Take off Video
    By J5Ron in forum Cafe Supercub
    Last Post: 12-16-2008, 09:17 AM
  3. DEAD STICK LANDINGS.
    By johnlinde in forum Member to Member
    Last Post: 05-14-2008, 09:44 AM
  4. Dead Stick Landings
    By Bob Breeden in forum Cafe Supercub
    Last Post: 09-07-2003, 05:40 AM
