Results 1 to 15 of 15
Thread: Big Tires
    Jan 2018
    North Carolina
    20
    Big Tires
    Any tips on how to make the holes line up on the 2 wheel halves when putting big tires on new wheels?
    We'll be installing Bushwheels on the aircraft. Just trying to put the tires on the new wheels now...
    Thanks in advance
    S2D's Avatar
    Montana
    4,053
    Couple ready rods
    Sent from my E6910 using Tapatalk
    Meanwhile,...
    5,002
    All thread is your friend, just crank it down then replace one at a time with the bolts.
    Jan 2018
    North Carolina
    20
    Thanks for the tips. We got'er done!
    18,651
    Here is the tool I made and use out of a large piece of all thread and some OBS wood washers which I discovered needed some metal back up washers. Goes in the middle and you can get to all the nuts on the wheel.
    Likes CamTom12, hotrod180, cubflier liked this post
    May 2014
    568
    Stick a couple long Phillips screwdrivers thru bolt holes to align things before snugging up Steve’s nifty tool
    18,651
    Quote Originally Posted by Oliver View Post
    I put the through bolts in before the tool to alighn everything but you just can't get the nuts started.
    Mikey's Avatar
    Everett, WA
    518
    2 long pieces of 1/4” all-thread
    1,663
    I like to put about 1 psi in the tire. The inner hole will expand and allow the rim to fit in easy. Really makes a difference when trying to mount up a set for a Beaver.
    PerryB's Avatar
    Aug 2007
    Northern Calif.
    1,798
    Yes, that and give the wheel and the inside diameter of the tire (if ABW) or tube a dusting of talc. I use Gold Bond.
    Likes DENNY liked this post
    Apr 2018
    55
    I have the same tool as Steve Pierce in my box. Very nice.
    G44's Avatar
    Oct 2011
    SW Michigan
    447
    Are you guys using talc powder when installing Bushwheels (31’s)? Have heard not to with Bushwheels.
    Kurt
    Likes Bowie liked this post
    18,651
    Talc is used so the tube slides inside a tire and centers up and reduces the risk of getting folds in the tube when air is added. I have seen no reason to use talc when installing Bushwheels. I do apply electrical tape to the back side of the wheel where the valve stem exits and then squirt black silicone in the hole to keep sand and grit out of the inside of the wheel.
    Thanks CamTom12 thanked for this post
    Likes FdxLou, DENNY liked this post
    1,663
    Use of Talc or soapy water is recommended on their site. Tailwheels is where it really helps. I have it on the shelf so I tend to just make a mess with it when working with tires. Just makes things slide better in general.
    https://www.airframesalaska.com/v/vs...reak%20ICA.pdf
    I remember reading something somewhere about not using baby power, but, baby power can be/is made of different ingredients.
    G44's Avatar
    Oct 2011
    SW Michigan
    447
    Excellent idea on filling the hole!
    Kurt
  1. BIG Tires VS smaller tires.
    By T.J. in forum Modifications
    Last Post: 06-18-2011, 01:14 PM
  2. Big tires
    By Stocky in forum Cafe Supercub
    Last Post: 04-25-2005, 08:41 PM
