Results 1 to 11 of 11
Thread: Aerothane question
    7,080
    Aerothane question
    Whatever else can be said about the “Ellis” Cubs, their fabric was beautiful - a work of art. I am tasked with supervising a repair - I will be trying to match 2003 Aerothane Cub Yellow.
    My question: I need to put a sandable coat of white on top of the Poly Spray prior to shooting the catalyzed yellow. Any thoughts or advice? I am a dope or dope and acrylic enamel kind of guy, and have never attempted any urethanes. I will have a spray gun expert shoot the last coat.
    19,607
    White Polytone. That is what I use over Polyspray (silver) prior to red, yellow etc. You should get a Polyfiber manual and read it. Lots of good information that you will probably enjoy reading.
    Thanks gdafoe thanked for this post
    Likes Hardtailjohn, CubCruiser liked this post
    7,080
    I read my first one in 1969. Bought stuff from Ray Stitts himself. My airplane is approved for Stitts through silver, then anything. Later manuals are less forgiving.
    My problem with Poly Tone is that it sands like rubber. This finish, to match, has to be dead smooth.
    May 2014
    645
    Ellis Clark J3?
    Not Aerothane, high solids automotive paint.
    He does do beautiful fabric work though.
    19,607
    Never had an issue with it being rough or sanding.
    Thanks windy thanked for this post
    7,080
    No kidding? It is clear he used Stitts fabric and Poly Brush.
    Tell me more. Logbook says Aerothane Cub yellow. His IA approved several major alterations. I converted them to field approvals. I am skeptical when it comes to log entries on this one.
    The fabric is quite flexible, and dead-smooth. You can barely see the pinked edges.
    Steve - one of our Cubs is Poly Tone Cub Yellow. It is pretty rough, and I have tried sanding and machine buffing. It really needs Aerothane. I have been using your trick with Poly Brush to keep the non-pinked tapes in place. It will never be smooth - I do not possess that kind of patience.
    11,076
    which Ellis?
    algonquin's Avatar
    Apr 2013
    Seldovia,Ak
    1,016
    Have you looked at Stewart System, there top coats shoot easy and smooth. They are very good to work with.
    May 2014
    645
    PM sent
    n40ff's Avatar
    Oct 2009
    WV
    956
    Ditto. Poly Brush is somewhat rubber like but IMO the rest of the process thru Poly Tone sands as well as dope. Most mistakes can be fixed with MEK.(not too much though)
    Later manuals are indeed "less forgiving" but many top coats applied like straight enamel and/or automotive finishes w/o flex agents didn't last and gave the process a bad name
    Jack
    7,080
    Yep. Talked to the original restorer. Poly Tone white under the yellow. I should be able to match the original - and the Wag wing rotator arrived today. Thanks for the hints. You guys steered me in the right direction.
  1. Aerothane vs Ranthane
    By stewartb in forum Tips and Tricks
    Last Post: 05-03-2016, 04:04 PM
  2. Aerothane vs Ranthane
    By Skip in forum Cafe Supercub
    Last Post: 01-18-2009, 07:50 AM
  3. Quick Stits Aerothane question
    By bob turner in forum Super Cub Sick Bay
    Last Post: 11-14-2006, 09:13 PM
