Results 1 to 15 of 15
Thread: Dented Fuel Tank
    Southeast
    13
    Dented Fuel Tank
    The top of my right fuel tank has been dented to where the top of the filler cap is now basically flush with the top of the wing tank cover. It hasn't been sucked in by a blocked vent, it was pushed on too hard by someone while unscrewing the fuel cap. It's a real pain now to remove the fuel cap, any suggestions on best method to pull the dent out?
    flyrite's Avatar
    Mar 2013
    Lyons,GA
    457
    I make my living, or use to among other things doing PDR(paintless dent removal) might be a good chance your dent could be fixed by a good tech. Check around at the Car lots to see who they use. Shouldn’t be a problem for a good guy!
    nd
    3,212
    could you make some kind of a T tool that hinges at the intersection of the T insert and pull it back up. just my first thought.
    Likes mike mcs repair, windy liked this post
    18,654
    Make a tool like a large toggle bolt and pull on it. It should pop right out.
    Mar 2016
    878
    I second Doug's approach, a J hook with a suitable handle for you to pull up on. Work it around the filler so you pull up evenly. It should not take allot of effort.
    There are other methods such as air pressure to inflate the tank but that has it's risks involved, primarily these tanks are not real happy with much more than a few pounds, some tanks can split a seam with as little as 5psi. Gas welded tanks generally hold up better than Tig welded tanks.
    If you choose to inflate a tank always fill it with water to greatly decrease the amount of energy the air can create. It can take quite a few sunny days to dry a tank that has been water filled before connecting it to go back into service.
    But as you say it was pushed down so it should pull up easily enough.
    Ah, Steve's toggle as well.
    Likes hellojac liked this post
    Chicken Hawk's Avatar
    Feb 2015
    Southern NH & Eastern Maine
    239
    Eye bolt through an old fuel cap. Twist fuel cap on & pull on eye bolt.
    Thanks hellojac thanked for this post
    Doug Budd's Avatar
    Feb 2015
    Crawford Nebraska
    152
    Check the neck where it attaches to the tank and make sure it isn’t cracking. I had a pacer tank that the neck was pushed down from resting gas cans on the filler neck and it cracked when it was pulled out. Could have been a bad deal if it had been rained on or washed
    10,439
    Times seven on the look for cracks around the neck. And don’t ask how I know that.
    C-FIJK's Avatar
    Jan 2005
    Lewisporte N.L.
    399
    Correct me please but are -18 fuel tanks not vented through the caps only ?
    Gerry Marcil
    Every day spent flying is a great day !
    10,439
    Quote Originally Posted by C-FIJK View Post
    No correction needed....you're correct.
    Thanks C-FIJK thanked for this post
    Southeast
    13
    Good ideas, I’ll see what I can do to pull the dent and watch for cracks.
    May 2014
    59
    This captured my interest and am just curious: Are -18 wing tanks vented across the birdcage to each other?
    9,288
    Quote Originally Posted by motosix View Post
    No.
    18,654
    They are if it is modified with the Cub Crafters or Dakota Cub headerless STC.
    Dec 2014
    3
    I managed to get a Maule main, the old pillow type up to 20psi before the seams began to open. the dents that became nice and smooth became dents again.
  1. WTB Left Hand PA-18 or PA-11 Fuel Tank, straps, tank cover
    By supercub in forum Parts and Pieces
    Last Post: 01-21-2019, 12:10 PM
  2. Fuel tank leak right tank
    By RAC cubs in forum Tips and Tricks
    Last Post: 11-11-2010, 02:18 PM
  3. Dented boot cowl
    By Rob Murray in forum Cafe Supercub
    Last Post: 10-15-2009, 06:13 AM
  4. Fanny dented Strut
    By Cajun Joe in forum Super Cub Sick Bay
    Last Post: 10-22-2005, 03:39 PM
