Page 2 of 2 FirstFirst 12
Results 41 to 71 of 71
Thread: Engine starving for fuel
  1. #41
    Doug Budd's Avatar
    Feb 2015
    Crawford Nebraska
    246
    Thank you all for all your ideas to help me out.
    Thanks RookieCubPilot thanked for this post
  2. #42
    kiwicubber's Avatar
    Jun 2007
    Te Kowhai, New Zealand
    170
    What does wot mean?
    Bill and Neroli.
    www.supercub.co.nz
  3. #43
    supercrow's Avatar
    Dec 2008
    528
    wide open throttle
    Thanks kiwicubber thanked for this post
  4. #44
    kiwicubber's Avatar
    Jun 2007
    170
    Ah yup, that makes sense ����*✈️��
    Bill and Neroli.
    www.supercub.co.nz
  5. #45
    Mar 2020
    Dyersburg, TN
    31
    Increase the size of the fuel lines by 125%.
  6. #46
    Doug Budd's Avatar
    Feb 2015
    Crawford Nebraska
    246
    Quote Originally Posted by Joe McMillen View Post
    Wasnít the fuel lines. I didnít have covers on the gooseneck fuel caps and it was letting dust get in the tanks and plugging up the filter. When I would land it would back flush the filter and run ok for awhile. I put cover on the gas caps and a quick drain in front of the filter to sump it. No problems now
    Likes Joe McMillen liked this post
  7. #47
    33
    About 7 days to final inspection on my Experimental Super Cub, with a Titan IO-370, with electronic mags. Checked gravity fuel flow in a 3 point attitude at the inlet of the Aeromotive Silver Hawk, and got 17 gal per hour, from both tanks. Have read where it should be a certain amount above highest consumption, which I suppose would be about 15 or so an hour. Does this sound like the correct flow. Using 3/8 fuel lines. Thanks
  8. #48
    11,349
    Quote Originally Posted by planenuts View Post
    Sounds to be too low. Do you have the pressurized fuel cap vents? That will help.
    This is the FAA requirement for certified airplanes:
    CAR 3
    3.434 Fuel flow rate for gravity feed systems. The fuel flow rate for gravity feed systems (main and reserve supply) shall be 1.2pounds per hour for each take-off horsepower or 150 percent of the actual take-off fuel consumption of the engine, whichever is greater.
    3.435 Fuel flow rate for pump systems. The fuel flow rate for pump systems (main and reserve supply) shall be 0.9 pound per hour for each take-off horsepower or 125 percent of the actual take-off fuel consumption of the engine, whichever is greater. This flow rate shall be applicable to both the primary engine-driven pump and the emergency pumps and shall be available when the pump is running at the speed at which it would normally be operating during take-off. In the case of hand-operated pumps, this speed shall be considered to be not more than 60 complete cycles (120 single strokes) per minute.
  9. #49
    May 2021
    Arizona, USA
    230
    Given that the Silver Hawk is an injection servo, and that this airplane probably has 2 fuel pumps, wouldn't the required test be with a single pump running rather than a gravity feed test? If both pumps fail the engine is going to quit no matter how fast the gravity feed.
    Just asking.
  10. #50
    11,349
    Just asking.
    If his engine is producing 195 hp(?), he should be flowing about 29-30 gph with the aux pump running. 195*0.9=175.5/6=29.25 gph.
  11. #51
    55-PA18A's Avatar
    Dillingham, Alaska
    680
    Interesting topic, and should be in its own thread, not in one about intermittant fuel starvation.
  12. #52
    3,874
    It's interesting that the Part 23 fuel flow requirement is slightly less stringent than CAR 3, which is quoted in #48.
    Here is 23.955
    "(b) Gravity systems. The fuel flow ratefor gravity systems (main and reservesupply) must be 150 percent of thetakeoff fuel consumption of the engine.(c) Pump systems. The fuel flow ratefor each pump system (main and reserve supply) for each reciprocating engine must be 125 percent of the fuelflow required by the engine at the maximum takeoff power approved underthis part."
    https://www.govinfo.gov/content/pkg/...ol1-part23.pdf
    Edit: FWIW, data from my -12:
    Conditions:
    Fuel lines are 3/8” aluminum tubing.
    Right-hand tank only, because it has the longest run of fuel line and no forward outlet.
    Approx 5 gallons of fuel in the tank
    Pitch angle is 11 deg up from 3-point attitude, which corresponds to full power, no-flaps climb at 40 MPH.
    3-point attitude is 11.5 deg up from level HRL. Therefore, total pitch up angle of the HRL is 22.5 deg for this fuel flow test.
    Fuel line disconnected at the carburetor and flowed into a 250 ml graduated cylinder.
    Flow start-up for each test is not instantaneous - it takes approx 1 second to fully develop due to inertia of the fuel column in the line. Therefore 0.5 second is subtracted from each flow time.
    Data:
    Trial #
    Volume (ml)
    Measured Time (sec)
    Adjusted Time (sec)
    Adjusted ml/sec
    Adjusted gal/hr*
    1
    218
    7.6
    7.1
    30.7
    29.1
    2
    219
    8.9
    8.4
    26.1
    24.8
    3
    215
    9.1
    8.6
    25.0
    23.8
    4
    210
    7.7
    7.2
    29.2
    27.8
    Average
    26.4
  13. #53
    33
    CAR 3
    Does look like mine is low, looks like about 22.5 or higher is needed. I do have the Altee caps with forward snorkels. Will disconnect from the fuel selector outlet and see what I get there. Note the engine runs fine with no fuel pump on, but will not turn up full static RPM. Click image for larger version.
    Thanks for the reply
  14. #54
    11,349
    Is that prop a constant speed or ground adjustable? Adjust the low pitch stop to a lower blade angle for more static rpm. If it has a governor, back out the high rpm stop screw for more rpm.
    Did you run your aux fuel pump to get your flow rate? That should flow more fuel.
  15. #55
    May 2021
    Arizona, USA
    230
    What is the fuel pump configuration on this airplane? I would expect an engine driven mechanical pump and an electric aux pump. What is the fuel pressure with no pump running?
  16. #56
    Grant's Avatar
    At Work.....
    1,899
    make sure you have the correct pump on the engine....I learned that the hard way.
  17. #57
    33
    It is a ground adjustable Whirlwind prop, set at 15 degrees. Fuel flow was gravity only no pump. The engine does have an electric pump, and mechanical. The mechanical was shipped on the new engine. Aeromotive suggest in trouble shooting that, if you can not increase RPMs over a certain level, it may be oil in the air chamber. Some what typical on an updraft set up for Lycoming type engines.
    Thanks for all the help, will see what we find out
  18. #58
    11,349
    Do the flow test again with the electric pump running. You will likely be happy with the results.
    Also lower the prop setting.
  19. #59
    33
    Did the fuel flow yesterday with the boost pump on, it nearly doubled the flow, about 31 gal an hour. That meets all the requirements mentioned. Still concerned if wot and fuel pump failed. Will keep working on getting the gravity flow up, but for now, the boost pump did the job.
    Really appreciate the advise and comments
  20. #60
    11,349
    If the fuel pump fails at wot, you just turn on the boost pump. That is what it is for.
    Do not be concerned with the gravity flow. You have a "pumped" system and do meet those requirements.
    Enjoy your new Cub.
    I have the same prop on my IO-360 Cub. It pulls like a work horse. You will be happy.
  21. #61
    May 2021
    Arizona, USA
    230
    You have 2 fuel pumps don't you. As I said earlier the engine will stop if neither is working. A carb will work on 0.5 psi or less but the injection servo needs at least 20 psi.
    If you are concerned about the engine driven pump you should run a test of its delivery. I don't know a standard way to do that but, unless I could find one, I'd pull the top plugs and crank the engine with the starter with fuel line disconnected at the fuel servo.
  22. #62
    2,968
    If concerned about fuel flow and pressure install a means to monitor. Fuel pressure/flow rate gauge or warning light that illuminates below a specified pressure. And practice pushing the secondary electric boost pump on switch so it becomes a routine if the engine burps.
  23. #63
    Jan 2017
    Utah/Alaska
    312
    This should get your attention. Can you disconnect the fuel line from the carburetor, place it in a 5 gallon gas can and fill the can in 15 minutes or less? That would be 20 gallons per hour. 1/4" for a fuel line is likely way too small. Generally you will find 3/8" as a minimum.
    The Taylorcraft requires a 5/16" ID fuel lines per the STC for the bigger engine than an a-65 so I use -6 for everything and when I put on the lycoming, I am using a -8. Tim
  24. #64
    Vermont
    381
    I have wing tanks, but with 4 check valves(2 pumps), fuel flow sensor, screen and filter, I don't expect much pure gravity flow. I do have a pressure gauge, it predicted a slowiy plugging filter(new tanks). My FAA guy was happy with an electric-only flow test. The worksheet he used seems to require an electric pump.
    The next step is to consider putting the aux in parallel with the engine pump, in case one pump fails plugged. But what if a pump fails open? Then you need external check valves. I've seen pictures of setups than must weigh 10 lbs. Haven't gone down that rabbit hole.
    What's a go-around?
  25. #65
    Jan 2017
    Utah/Alaska
    312
    Quote Originally Posted by Skywalker View Post
    Way too complicated, but if that is what you want, run with it. good luck, Tim
  26. #66
    Vermont
    381
    It's not what I want, and I don't have it. Just pointing out that with the typical 2 pumps in series you may not get much pure gravity flow. You have to take comfort in redundancy, not the simplicity of gravity.
    (most pumps have and input and output check valves built in)
    What's a go-around?
  27. #67
    Jan 2017
    Utah/Alaska
    312
    with wing tanks and a header tank, why a pump at all?
  28. #68
    May 2021
    Arizona, USA
    230
    Quote Originally Posted by astjp2 View Post
    Because injected engines won't run on gravity feed.
  29. #69
    4,050
    Why would you put the pumps in series?
  30. #70
    11,349
    Both of the gear pumps in my injected Cub are in series. Both the electric and engine driven pumps have built in bypasses should there be a failure or clogging of the basic pump. There are no additional check valves as they are not needed.
  31. #71
    Vermont
    381
    That's a good question, Web. On carbureted engines the pumps are basically two check valves with a variable volume chamber in between. The odds of both valves failing are slim. I would just run them in parallel, the odds of a pump failing open are slim. But no one seems to do this without big honking check valves you can barely blow through.
    I could tear out both pumps and go gravity, but having spotted a slowly plugging filter with a pumped and sensored system made me a fan.
    What's a go-around?
  1. Fuel Injection Engine Starting
    By stewartb in forum Tips and Tricks
    Last Post: 02-05-2018, 10:50 AM
  2. jet fuel engine
    By RAC cubs in forum Cafe Supercub
    Last Post: 03-04-2011, 12:37 PM
  3. Fuel Lines vis-a-vis 180 HP Engine
    By musket in forum Experimental Cubs
    Last Post: 07-01-2008, 04:32 PM
  4. Fuel capacity vs. engine horsepower?
    By gcgilpin in forum Modifications
    Last Post: 07-14-2006, 04:01 PM
