Results 1 to 21 of 21
Thread: lifting and launching
    Oct 2009
    Wanaka,NZ
    366
    Hi Guys,we are new at this game and need all the info we can get.We have a superb cub on floats. (PA-18108S).We need to make a spreader/lifting device to lift the rigged floatplane from the grass onto a trailer of some sort to do a launch off the trailer.Any advice on spreader bars, measurements would be appreciated.Our strip is 2000 feet of rough mown grass.Expecting a 10kt headwind for takeoff.Advice on a simple modified trailer.Note;floatplanes in New Zealand not that common so any inputs great.Thanks.
    Jan 2005
    Fowler, Ks
    569
    Tilt trailer?
    Oct 2009
    Wanaka,NZ
    366
    NO flat deck fixed
    Likes cubnut liked this post
    Ione Cub
    Jul 2017
    NE Washington
    4
    Made this to get mine off this past week. Worked great. I needed the elevated bunk to get over the wheel fenders and added a slight angle to help the launch.
    Geno
    Likes ron liked this post
    10,218
    Quote Originally Posted by ron View Post
    Get a couple friends and lift up on the tail of the plane till you can get a 6x6 under each step. Now pull down on tail till you can get a 6x6 under each float 4 or 5' in front of the first blocks. Repeat till high enough. When you get ready to put it on the trailer pull down on tail and remove front blocks and back trailer under floats. You can wiggle it on the last foot.
    Likes BC12D-4-85, skywagon8a, Olibuilt liked this post
    10,988
    If you’re going to lift the plane, you’ll need lifting eyes, preferably. Atlee Dodge sells them. Then you’ll need a spreader bar to prevent damage to your top deck. A piece of angle iron works, or similar. Cut it some longer than the width of the lifting eyes, then attach strong eyes to the spreader bar, same distance apart as the lifting eyes. To lift, attach the spreader bar to crane, attach an eye on the spreader to each lifting eye.
    Thanks ron thanked for this post
    Jun 2008
    TN
    62
    You guys may be missing the part where he wants to launch it off the trailer....... which I assume means he wants to fly it off of the trailer.
    Oct 2009
    Wanaka,NZ
    366
    yes kg is correct but all info I appreciate .Would anyone have a photo of a cub actually being lifted also please.Thanks .Ron.
    10,218
    Blocking & Rocking takes less then a couple minutes to put a floatplane on a trailer or dolly. We do it twice a year to 5 to 7 aircraft. Simple and safe, did I mention also cheapest way
    Oct 2009
    Wanaka,NZ
    366
    so what is blocking and rocking
    Feb 2006
    Maine
    772
    Used this for years before amphibs on my pa-11, it's steerable with a water rudder. exciting the first couple times.Click image for larger version.
ID:	44116Click image for larger version.
ID:	44117Click image for larger version.
ID:	44118Click image for larger version.
    Oct 2009
    Wanaka,NZ
    366
    thanks mvivion,yes we have the eyes fitted..What I would like to see is a spreader bar in place so we can make one up.
    Thanks jrussl, pfm thanked for this post
    3,611
    He explained in post #5.
    TurboBeaver's Avatar
    Jun 2009
    Northern Maine
    799
    Ron,
    This is what they look like........
    Mt Cook boys used to know all about them??? When I lived in Wanaka they had two C 206 in Te Arnu on 3430s.Click image for larger version.
    10,370
    ...Our strip is 2000 feet of rough mown grass.Expecting a 10kt headwind for takeoff.Advice on a simple modified trailer.
    Quote Originally Posted by genestone View Post
    Hi ron, How rough is your grass runway? One person's rough may be anything rougher than a golfing green. Is it just a little bumpy or does it have rolling hills?? When you have the plane on a trailer such as Gene's, pulling the trailer over rough terrain would be easy for the floats to bounce off those planks which are under his keels. I would place two long planks across the entire trailer which extend well beyond the keels of the floats just so the bouncing of the ride over the rough grass doesn't knock the floats off the trailer before you get to flying speed. Small wheels on the trailer will make for a bouncy run. Not good.
    Every dolly/trailer take off is an adventure until the plane is airborne. Most often they are successful, but sometimes they are not. Been there done that, both! Besides having a head wind make sure that the density altitude is low. It's really disappointing when you get a nice lift off only to find that the plane will not fly out of ground effect settling back onto the ground and have the dolly run into the back of the floats when it catches up to you.
    5,310
    My version of a spreader bar. Different shackle holes for different airplanes. Made from scrap steel and shackles I had laying around.
    Likes wireweinie liked this post
    Jul 2010
    Elizabeth, WV
    583
    Is this a one time event to get it to the water or will you be landing the floats on the grass ? Maybe just takeoff from the grass on a dewy damp morning?
    Oct 2009
    Wanaka,NZ
    366
    Quote Originally Posted by N86250 View Post
    Thanks N86250,The old girl has 108 hp,don't know if we could even get a knot out of her?!
    10,370
    Ron,
    While I can't vouch for the performance with only 108 hp, a wet grass attempt isn't out of the question. You certainly will not get tangled up with the trailer poking a hole in your floats in the process (done that with a Waco). Make sure that there are no hidden stones or other objects hidden in the grass which could damage the floats. Start the run with the stick full nose down. This will tilt the plane forward onto the curved section of the keels where there is minimum drag. Accelerate in the minimum drag position to flying speed. Accelerate to a speed greater than full flap stall speed since when you attempt to rotate the drag will go up quickly slowing the plane. Pull on full flaps when you rotate.
    I have landed on thin snow and muddy grass, with the stick full back the plane will come to a stop at full power using 150 hp. When I pushed the stick forward I was able to taxi it to the hangar very easily.
    I also have taken off gear up on dry grass with a Twin Bee. It used less distance taking off than it did landing.
    5,310
    I'd be careful about too much AOA. If flat the airplane will decide when to fly off. With the nose high it may suffer from premature ejaculation, and nobody wins when that happens.
    AdirondackCub's Avatar
    Jul 2012
    Ballston Spa, NY
    153
    Cubdriver2 answered the first question perfectly. You said you landed it in the grass on floats and now need it on a trailer. In less than 5 min and with just blocks of wood, we get these cubs up on trailers and then reverse the process and put them away for winter storage. We do it with 2 guys even. Then we can either tow the trailer for a takeoff or back it into the water. KISS method and as Glen said cheap.Click image for larger version.
ID:	44151Click image for larger version.
  1. Replies: 7
    Last Post: 09-28-2017, 02:04 PM
  2. Lifting a SC?
    By CptKelly in forum Cafe Supercub
    Last Post: 10-08-2015, 08:43 AM
  3. Launching with Bobby
    By Bob Breeden in forum Member to Member
    Last Post: 04-30-2010, 05:25 AM
