Thanks Thanks:  0
Results 1 to 4 of 4
Thread: Extended baggage
    Jul 2019
    O’Fallon, MO
    25
    Extended baggage
    How hard is it to install the extended baggage STC.
    11,076
    Which one?
    jrussl's Avatar
    Jul 2005
    Madison, WI
    555
    Atlee makes one that is designed to be installed in a covered Supercub but it is very small. I had one in my cub early on and upgraded to the Cub Crafters baggage during rebuild.
    http://www.fadodge.com/extended-baggage-kit/
    Others require extensive welding and usually are done during rebuild.
    http://store.cubcrafters.com/Extende...gs_p_1593.html
    I just got a cargo pod last summer and like it way more than any extended baggage. Easily installs on any cub.
    Call Bob Piatt (907-376-7259) and get a Firmin pod. You will really like it.
    Jeff
    Likes FdxLou, wireweinie, mike mcs repair liked this post
    behindpropellers's Avatar
    Feb 2003
    NE Ohio
    6,792
    Quote Originally Posted by jrussl View Post
    Jeff
    This really is the best answer:
    1. Because it keeps the CG in the right spot.
    2. You can load your heavy stuff in it that will kill you in a crash.
    3. You can take it off and install it in 15 minutes.
    4. Just easier to get to everything.
  1. extended baggage
    By Skip in forum Cafe Supercub
    Last Post: 12-15-2010, 08:19 PM
  2. extended baggage for PA-11?
    By AviatorPA11 in forum Cafe Supercub
    Last Post: 03-04-2009, 10:49 PM
  3. Extended baggage.
    By Tig'n in forum Modifications
    Last Post: 02-09-2006, 11:42 PM
  4. Extended Baggage for PA-12
    By N7623H in forum Modifications
    Last Post: 10-18-2005, 01:34 PM
  5. Extended baggage
    By Crosswater36 in forum Tips and Tricks
    Last Post: 10-07-2004, 10:19 AM
