Extended baggage
Atlee makes one that is designed to be installed in a covered Supercub but it is very small. I had one in my cub early on and upgraded to the Cub Crafters baggage during rebuild.
http://www.fadodge.com/extended-baggage-kit/
Others require extensive welding and usually are done during rebuild.
http://store.cubcrafters.com/Extended-Baggage-With-Cargo-Net-and-Tie-Down-Rings_p_1593.html
I just got a cargo pod last summer and like it way more than any extended baggage. Easily installs on any cub.
Call Bob Piatt (907-376-7259) and get a Firmin pod. You will really like it.
Jeff
Jeff
This really is the best answer:
1. Because it keeps the CG in the right spot.
2. You can load your heavy stuff in it that will kill you in a crash.
3. You can take it off and install it in 15 minutes.
4. Just easier to get to everything.
