Results 1 to 4 of 4
Thread: Props at altitude
    txpacer's Avatar
    Jun 2011
    Iowa Park, TX
    615
    Props at altitude
    I was recently told by someone with much more mountain flying experience than me that the Borer prop is not such a great climber above 5000 feet, that I would be better off with the stock Sensenich at that altitude. I can see the logic to that, based on how my plane performed in the mountains and thinking about how the prop loads the engine. I'm thinking about putting a Sensenich 74-56 on for my next trip. Any thoughts or experience on this? How does the McCatto do up high?
    RaisedByWolves's Avatar
    Feb 2005
    3,732
    I’ve heard the Catto does good out west. 82/40
    DJ's Avatar
    Jan 2009
    Bolivia
    180
    I like it but i dont have experience with other props at altitude. I climbed to 16,500 (DA 18.5K) the other day loaded with about 450 lbs of pax and gear. Kinda slow the last 2000 ft but no problem. I'm turning the 86/38 Catto 2550 rpm in a 60 mph climb. Click image for larger version.
    Likes eskflyer liked this post
    Feb 2006
    Cortez Colorado
    81
    I fly a 160 SuperCub with a Borer prop 82/43. It does quite well at our altitude of 6,000 on up to 10,000 on takeoff and climb. I suspect that as you go higher in altitude you might want more pitch in the prop, not sure. Seems to have more power than pull the higher I go. I usually climb out at 2,500 rpm once out of the runway area having throttled back a ways. It would be interesting to have two cubs of the same horsepower with these two prop setups fly at 60 and full power.
  1. Too much Altitude?
    By PA-18 in forum Cafe Supercub
    Last Post: 08-25-2005, 09:43 PM
  2. Climb props and altitude
    By KenyaCub in forum Modifications
    Last Post: 12-13-2004, 11:21 AM
