Results 1 to 9 of 9
Thread: J-3 Fuel Tank Install
    Nov 2007
    NW Mn
    62
    I just purchased a J-3 that had the fuel tank removed. A new tank was included in the deal, but not installed. Any idea what mods I need to do on my arms to get the thing installed?
    supercrow's Avatar
    Dec 2008
    533
    I assume the two removable tubes are out? After that it is simply a real bitch that takes some patience and skin loss. Put the tank strips in very loosely and work the tank into them before tightening them up. Will take an hour of so and the next time (hope not eh?) will go a little easier. But not much. It's not that bad, really, but go slowly and don't force anything.
    Thanks mbsyvers thanked for this post
    Nov 2007
    NW Mn
    62
    The tubes have been removed, just having difficulty getting it into front straps and filler neck out through cowling. do the straps (top and bottom) get bolted together or are they separated by the tube the bolt runs through?
    7,596
    Go over to the J3 Cub forum and search. All of mine have the straps split and bent on the bottom. Tank goes up, straps rotated in place, 10-32 threaded rods pull the straps together - ten minutes. Not my original idea - my personal Cub came that way in 1962.
    supercrow's Avatar
    Dec 2008
    533
    Quote Originally Posted by mbsyvers View Post
    Together, but many have been modified by now to make it easier. Often times made so that they can be brought together at the bottom. As long is it is secure, make it work for you.
    Nov 2007
    NW Mn
    62
    Thanks to you both. It will be in my hangar Monday.
    Oct 2021
    2
    I am installing my tank and am having problems with the straps not fitting correctly. Do you have any pictures how the clamps look after tightened on the tank? I am restoring this plane and have complete access and boot cowl is off.
    7,596
    If you split them on the bottom you can make them fit. I believe both straps rest on top of the frame, at least originally - they apparently put the straps on, then dropped the tank in, then put the boot cowl on. You can see how difficult that made removal.
    The originals had 1/4" thick felt between straps and tank. And remember - front and back straps are different.
    Dec 2017
    1
    J3 fuel tank straps
    My tubes would not come out so I removed the boot cowl. The flange on both straps go on top of the bushing that is welded to the frame. The MS35207-271 screws are held to the top strap with a AN 315 jam nut and at the bottom of the bushing with 2 nuts.
    Tom Dusin
  1. WTB Left Hand PA-18 or PA-11 Fuel Tank, straps, tank cover
    By supercub in forum Parts and Pieces
    Last Post: 01-21-2019, 12:10 PM
  2. Replies: 10
    Last Post: 06-03-2011, 03:20 PM
  3. Help Needed For Belly Tank Install.
    By Steve Pierce in forum Modifications
    Last Post: 11-23-2010, 11:10 AM
  4. Approx cost of wing tank install
    By a3holerman in forum Modifications
    Last Post: 09-25-2006, 07:34 AM
