Near HIT (near-miss never made sense)
Flying_Fin
Medway, Maine
Flying from Oxford Maine home to Millinocket today, 40 degrees magnetic heading, at VFR 3500' altitude. Over Brownville Junction, a Cessna Caravan appeared at same altitude, in FRONT of me, flying to the north, and my first view of it/him/her was as it made a drastic right climbing turn about 200' in front of me. I passed through his wake turbulence, and damned near s*it my pants.
I guess the only thing VFR rules do is guarantee a less than 180 degree collision.
Home save to KMLT, and was shaking when I landed.
Here's a shot of leaving Oxford.
Cheers. Keep those eyes open.
Couple thousand above ground, VFR cruising altitudes do not apply. I think they start at 3000' agl. In hilly country you use the peaks for ground level.
I have had ATC tell me I couldn't cruise at 2600 feet because it wasn't an approved altitude for my heading.
I had to look it up. I guess I never knew about the AGL thing.
[h=2]VFR cruising altitude rules in the US and Canada[edit][/h]In the US, there are specific VFR cruising altitudes, based on the aircraft's course, to assist pilots in separating their aircraft while operating under visual flight above 3,000 ft above the surface (AGL) but below 18,000 ft Mean Sea Level (MSL). Unofficially, most pilots use these rules at all levels of cruise flight. FAR 91.159[SUP][4][/SUP]
Guess I'm sorta "Unofficial"
Uhm, below 3000' there are no approved headings are there? Maybe I haven't kept up.
Totally unrelated photo of a painting I bought in Italy 30 years ago.
Most Caravans since the early 2000's have G1000 and I am willing to bet since this is a working aircraft it would have ADS-B. In any event even if it was Mode C your ADS-B in from ATC would give you a heads up on your headset either using the aux output or bluetooth. Using ForeFlight and their Scout receiver (199 dollars) you could have had an audio alert of the inbound traffic. So would you rather spend 200 bucks, or have what happened to you happen again?
https://flywithscout.com/index.html
https://flywithscout.com/index.html[ /QUOTE]
I'm subscribed to iFlyGPS.com , and I make plenty of money, and am not afraid to spend it. I'm selling the plane and will leave upgrades to the new owner. At 3500' over Brownville I can't use flight following from Boston or Bangor. Apparently terrain is blocking me from their radar, but not sure what actual issue is.
I guess I don't know enough about ADS-B and what it does, so I'll go visit Doctor Google.
I also asked the support folks at iFlyGPS if they have a similar product. Seems pretty simple. Not sure if it shows just weather though from the video.
I have an Ifly GPS 520. 1-2 yrs ago at their booth in OSH they offered a little Ping ADS-B in receiver to plug into it for under $100. Works well even for this Luddite.
Flying_Fin, I did not see, do you have a Mode C transponder? The caravan should have picked that up.
I'm a pretty big fan of ADS-B, and feel like we are getting more than we are giving up (privacy). We have certainly avoided close encounters with it more than once.
One of my near mid-airs was during my primary training, we were doing power off stalls, and I looked to the right and saw a tomahawk doing a very nose high climb and turning our way with our wing tips about two feet apart. Kept me awake for many nights thinking of what could have been.
Yes Cub does have mode C and I was squawking 1200. I don’t know enough about the system to know if I had to be visible to somebody with a radar or not and frequently in this part of the state it is very difficult to make radar contact due to the terrain.
Slightly off topic, but do any of the ADS-B systems have aural traffic alerts? If the two planes that collided near Ketchikan had aural alerting I suspect the accident wouldn’t have happened.
I run ADS-B in via a Garmin GDL39 displaying on a Garmin 796 and the traffic display is great providing location relationship to me on the moving map, Mode C elevation difference, and target track of multiple conflicts. The system also works on a 496 but requires hard wire connection vs Bluetooth. It shows traffic on the primary map screen when zoomed in and depending on the settings you hear “Traffic” in your headset when the presets are busted and a detail screen pops up.
Not much of a fan of ADS-B Weather and the NOTAM data has proven to be unreliable but I really like the traffic reporting.
Yes, but it is your app / gps that provides it, not the unit - except in the case of the new integrated garmin units.
Yes. Foreflight will give an aural alert. I have Bose A20 with bluetooth so when the iPad barks, it comes through the blue tooth. Example: "Traffic 2 O'clock, 1 mile 100 feet below". I actually like it much better than TCAS that would simply start barking "Traffic....Traffic" then would leave it up to you to look at the display, see the position, the start looking. On the other hand TCAS will bark a resolution advisory when you are about to collide where ADS-B leaves it up to you to resolve any conflicts. If you don't have bluetooth, simply run a line from your iPad to the aux input on your headset. Besides giving you an aural traffic warning it also will give you runway warnings, a 500' warning when approaching a runway and a warning if the airport you are approaching is not on your flight plan. I had an embarrassing moment the other day riding on an airliner out of ATL. I wanted to look at the airport chart for KGGG so I opened Foreflight on my iPad. As the airliner approached 26L in KATL it barked, "Approaching 26L" then it barked "Entered Runway 26L, 9,995' remaining" before I could get the volume turned down. Equally so approaching KSHV on the same flight it barked, "500' Runway 32, Shreveport Regional, airport is not part of any flight plan". Nice. I'm going to miss Foreflight when I switch to Garmin Pilot.
Sounds like it should ask what you want for dinner, table or booth, wine list, menu, and background music, then what hotel you want.
Seriously, it sounds great. What is the product name and is it a device to bluetooth to an iPad or iPhone?
Can you send a link. Foreflight and what else.
You need an iPad. You need a ForeFlight subscription. You need a device and ADS-B in device.
https://www.foreflight.com
The Scout is the cheapest device, there are others that are better.
https://www.foreflight.com/connect/
Hook your iPad to your headset either with Bluetooth or a patch cord.
Need to look at how to put a patch or bluetooth to my David Clark headphones from my iPad or iPhone.
Thanks, I will look at these, and appreciate your help/concern.
Together we do better than apart.
Cheers
iFly gives you a good warning, You do need an input to your tablet though. Presuming you are working with a Droid the Stratux system works quite well to provide you with ADSB in as well as synthetic vision, as well as being quite cost effective.
The warning system is visual at least in my usage, mid display on the left it will give you either a yellow or red warning symbol and the aircraft in question will be displayed in red. If you tap on any of the aircraft displayed you get a popup box with the targets altitude, heading, distance from you and closing rate or gain.
It might have an aural warning but mine was never hooked into the plane's audio panel.
Looking into this.
I have an iPhone and an iPad for devices, and iFlyGPS is registered on both. The iPad did not seem to get a good GPS signal suspended between the forward cockpit frame at eyelevel (only place it would fit) so I use the iPhone which gets full 4 bar GPS signals, and works fine.
Again, thanks
Scariest absolute 20 seconds of my life.
Would like to avoid in future.
With just the internal GPS you do not get much benefit for the features within iFly or any of the other nav programs. It will tell you where you are so you can map where you want to go but no other "features" are available to you. One of my phones has a decent GPS receiver but I need two pairs of Magoo glases to see something that small. The real issue with most phones and tablets is they want to lock onto the A-GPS before they give you much of any true GPS. Fine if you are near cell towers and not up at any altitude where there is no cell service. But that is probably above the desired ceiling of most pilots whom are out to play not to mention you have fewer towers up your way than over here in VT which is essentially nonexistent coverage.
For your Iphones the Stratus is the most common device to provide you with full features but it is far above the "Chump change" pricing the Stratux is.
Your iPad will give you VERY accurate GPS if it has the capability to receive cellular signal (does not have to be activated). That model has a very good GPS chipset in it. If you have a WiFi model, not so much. iPhone naturally has a good GPS receiver in it because it needs it to locate itself to the network. If you have a WiFi only iPad, I would recommend you invest in a GPS+ADS-B In unit such as Stratus, Sentry or Dual. Sometimes you can find a used Stratus 1 or 2 for sale for a good price.
Just flew from New England to Alaska and back with a new iPad Mini with cellular. No external GPS connected and it was extremely accurate for the entire trip.
Im sure that would have been a wiggins caravan hauling freight from Manchester NH to presque Isle, ME. HE would be with Boston center Hard to imagine that boston didt call you out to him if they could see your mode c. I would get on with BGR approach and see if they can see you
jim
Don't forget that after 2020 and all of you are loaded up with a warm fuzzy feeling of security that there will still be a bunch of us out there that don't have a transponder or ADSB. And I fly thru Maine in two different quiet aircraft quite a bit. I look out the window at more then the scenery. ;-)
Certainly fine to live the life of "the silent service". I would say this. Maine has a lot of MOAs and IR and VRs. Personally if I wanted to fly silently while the rest of the world flew out loud, I would invest in a inexpensive transponder even if I did not have a comm. At least the fast movers would see me. How fast?
Here is an F-16 vs a C-150. Here is a cockpit view from the C-150
https://www.youtube.com/watch?v=AerEgucD6J4
How many military aircraft have hit an aircraft in a MOA in the last 50 years? The Adirondacks have MOAs and most of us around here have a couple thousand or more hrs flying in them year round. Alot don't have a charging system.
