Results 1 to 22 of 22
Thread: Identify This Fuselage
    Henny's Avatar
    Jul 2011
    Ely, MN
    354
    Anybody tell what this is from the photos? Thanks.
    Henny
    RVBottomly's Avatar
    Sep 2017
    604
    The wood ribs look like Wag Aero ribs for a sport trainer or 2+2. The fuselge looks cub-like. I can't make out the photos on my phone very well, but I'm guessing it was a Wag project.
    Vic
    Sent from my SM-J320V using SuperCub.Org mobile app
    Steve's Aircraft (Brian)'s Avatar
    White City, Oregon
    901
    Quote Originally Posted by Henny View Post
    Henny
    Piper J-3 or derivative of a J-3..
    With the wood ribs I would say it might be an L-4..
    Brian
    1,761
    That would be a money pit fuselage. Lots of people see them but don't know what it really is, often go by the names of great deal/steal/bargin/simple project. Some even have wings on and are flying. Is that toe brakes I see?
    Henny's Avatar
    Jul 2011
    Ely, MN
    354
    I believe this is the engine that came off of it...
    9,561
    Tango Cub PA-18 fuselage?
    Continental A-40, I doubt that this engine was intended for this airplane. If it was, hopefully the pilot was small and planning to fly at sea level.
    Likes Flying_Fin liked this post
    WhiskeyMike's Avatar
    West Boxford MA
    897
    I don't think these parts are related except as bits and pieces gathered in the hope of making something. Could be a legit J-3 fuselage, or maybe a J-2 with the 40HP but I don't think any Cub had wood ribs.
    Mar 2016
    1,051
    My J-4 has wood spars and ribs which was not uncommon. The J-2 I worked on was wood spar, aluminum ribs but I recall my father saying the J-2 he learned to fly in was wood rib.
    If I recall I still have original cowl pieces here from that J-2.
    Cub Special Ed's Avatar
    Oct 2016
    MT/SD
    453
    J3 had the bars coming up from between rudder pedals to corners of panel didnt they?
    "There are 3 kinds of men. The one that learns by reading. The few who learn by observation. The rest of them have to pee on the electric fence for themselves." Will Rogers
    West Boxford MA
    897
    I've seen loads of wood spars, but never encountered wood ribs from Piper. I have no experience with J-4's. Anyone else know about this? I'm curious. There were plenty of variations. Early J-3's had recesses in the floor for some older kind of brake cylinder, and some early J-3s had an extra vertical brace in the landing gear V. My folks were told that that model J-3 was not legible for 85HP upgrade. J-2's had a rope like cord for the trim cable instead of wire and you just moved the cord with your hand - no crank. Sorta like when your single pulley trim stops working...
    9,902
    Quote Originally Posted by WhiskeyMike View Post
    I've been around a lot of J4s and I'm pretty sure none were made with wood ribs. I also have E2 and J2 Cub time and I loved the clothesline trim, simple and worked great.
    Likes AKjurnees liked this post
    RVBottomly's Avatar
    Sep 2017
    604
    I guess there is nothing new. I was wondering why nobody tried a line of some kind for trim. A couple wraps on a boat winch has a lot of grab.
    Mar 2016
    1,051
    George D whom chimed in on my build thread, flew his J4 up to visit, his is also a wood rib plane.
    nd
    3,350
    i read somewhere, where piper started using aluminum ribs after 1940.
    9,902
    I just texted Clyde and asked if J4 have ever had wooden ribs. He said " never "
    Wood spar but Alum ribs
    nd
    3,350
    heres where i read the 1940 deal. end page 22 https://books.google.com/books?id=n4...rcraft&f=false
    jon s. blocker's Avatar
    Oct 2002
    corpus christi, tx
    211
    Henny, It's a Wag Aero. Just spent 4 1/2 years building one almost to the finish before health problems made me stop. I recognize the wood ribs in my sleep, (26 counting the two tip ribs). L4s never had wood ribs,(I was building mine as an L4 and did a TON of research). The fuse is REAL close to the J-3, but notice the pass, side window should go down into the fuselage instead of stopping on the longeron, the 3/8ths inch channel at the front should weld directly to the vertical longeron making up the fire wall structure. on and on and on, it's a Waggy. Jon
    Hyrdflyr
    San Juan Islands, WA, WY, AZ,NM,UT
    254
    I think I saw a similar engine on some military target drones about 60 years ago. I think McColough made some of them.
    Sent from my R1 PLUS using SuperCub.Org mobile app
    Jan 2016
    24
    Ummmm, you have a problem, a major one if your J-4 has wood ribs and is in your certified aircraft. No J-4’s had wood ribs, only wood spars, the J4E models had metal spars.
    9,561
    Quote Originally Posted by Hyrdflyr View Post
    Henny's is a Continental A-40 which was used in the Taylor E-2 Cub.
    This is a McCulloch 2 cycle drone engine.
    18,983
    Looks like a J3 fuselage to me. Can't see anyone taking the time to make those tail inspection frames like the J3 and don't most Wag Aero's have fixed trim? It isn't to early unless someone changed the tail spring pad. Door hinges and boot cowl supports are J3.
    9,561
    You're right Steve, the front spar attach locations are in the center.
  1. Vibration I Can't Identify
    By Steve Pierce in forum Super Cub Sick Bay
    Last Post: 11-03-2010, 03:06 PM
  2. Identify where this picture was taken
    By Christina Young in forum Cafe Supercub
    Last Post: 07-18-2005, 05:43 AM
  3. Help me identify this plane
    By bradc314 in forum Cafe Supercub
    Last Post: 03-19-2004, 09:10 PM
