Page 2 of 3 FirstFirst 123 LastLast
Results 41 to 80 of 102
Thread: The "BEST" tie downs
  1. #41
    Mar 2007
    Alaska
    107
    I could be the most unskilled pilot out there and If I made good decisions I would never put an airplane at risk. That includes choosing how and where to tie down an airplane, and when to move it out of a bad situation. High on the list of decision making assets is local knowledge. That’s why employers and insurers place a high premium on Alaska time even though alaska time is no guarantee of good decision making.
    Some places in Alaska the big winds always come from the same direction. Other places as the low passes the wind shifts all the way around the compass rose. This Thread brings back memories of one storm out west where another member here and I spent the night moving our cubs into the wind. By morning our two cubs were the only ones on the field without our wings lying on the ground, including the guys that used the two by four method of lift strut protection.
    In other places moving my airplane out from being downwind of under secured airplanes saved my bacon several times. I did that in anticipation of weather events. Couldn’t have moved once they started.
    Likes Dave Calkins liked this post
  2. #42
    Apr 2017
    Anchorage Alaska
    57
    Logjam,
    Some very good thoughts. I'm on floats now so along those same lines, multiple ropes, attachments to solid parts of the aircraft, on floats not just the float cleats but around the strut attachments to the floats, on the wing a loop through the wing struts.
    When I tie-down on water I look at which way the winds are blowing and think about what might happen to the airplane if a strong gust came along. Ideally I'd want it to turn into the wind if possible yet not travel down the shore and hit another airplane.
    I use duckbills on shore, a line from the float strut in to shore, a line out to the back of the floats on each side with separate anchors for each.
    I can loose 2 or 3 of these lines and still hold the plane at the tie-down.
    Its also helpful turning the plane around since I can go different directions depending on the wind. It always wants to weather vane into the wind so use it to your advantage.
  3. #43
    376
    Where does one buy the duckbills tie downs with the wire to pull them out? Thanks.
  4. #44
    5,129
    In the Anchorage area we have multiple dealers. Elsewhere? No idea. And FWIW, you don’t pull them out. You might dig them out but I don’t know anyone who would. Use them and leave them.
    Thanks DavePA11 thanked for this post
  5. #45
    10,901
    Quote Originally Posted by DavePA11 View Post
    Here: https://www.amazon.com/s?k=duckbill+earth+anchors&adgrpid=58883126874&gcl id=EAIaIQobChMIqprBkZjg4wIVUxx9Ch1LQA9SEAAYASAAEgJ 5n_D_BwE&hvadid=274839608079&hvdev=m&hvlocphy=9021 324&hvnetw=g&hvpos=1t1&hvqmt=e&hvrand=700099299060 5914554&hvtargid=kwd-302450881565&hydadcr=12162_10197798&tag=hydsma-20&ref=pd_sl_7bcm47x9h1_e
    Or, they are commonly used to guy power poles, etc. so an electrical contractor store.
    Ive seen them at Lowe’s also.
  6. #46
    Chicken Hawk's Avatar
    Feb 2015
    Southern NH & Eastern Maine
    245
    Iíve never seen the 2 wire duckbills for sale anywhere. Most people add the second wire themselves. Just drill a hole in the longest part of the open end & install your own pull wire. You can get them to come out in softer soils.....not so much in tight compacted earth.
  7. #47
    algonquin's Avatar
    Apr 2013
    Seldovia,Ak
    1,016
    The company’s that sell the tarp covered buildings sell them, Shelter lodging I think is one.
  8. #48
    Feb 2015
    245
    Anybody tried these?
    4'' Earth Anchor (4 Anchor Set) W/3/16'' Cable Assembly https://www.amazon.com/dp/B07BWSSFQ2..._d2HqDb2F4MEJM
  9. #49
    376
    Thanks for all the feedback. So even Amazon sells them without the retrieval wire that people add, and from Stewartb the #68 is the correct size. I can see now how this could be an issue at airports on grass for mowers if used for a lot of planes and not retrieved.
    https://www.amazon.com/Pack-Duckbill...gateway&sr=8-1
  10. #50
    5,129
    In soft soil you can drive 68s with a piece of rebar but in stubborn soils the tempered drive rod is worth having. Rebar will fold up when the ground is hard. The drive rods are very tough, even against glancing blows from a tired old man.
  11. #51
    376
    Quote Originally Posted by logjam View Post
    Logjam - I think having the weather smart apps help in forecasting the bad weather to make those decisions. Much harder in the past without them. IMO.
  12. #52
    55-PA18A's Avatar
    Dillingham, Alaska
    632
    [QUOTE=Chicken Hawk;751654]Anybody tried these?
    These look interesting. Reviews indicate they work well in rocky soil. The aluminum duck bills don't do so well in rocky soil.
  13. #53
    JWE's Avatar
    Jan 2018
    NC
    84
    Anyone have any experience with the Big Screw tie down system? They claim 1200 lbs per screw.
    https://www.youtube.com/watch?v=eW7vG7Qwmnc
  14. #54
    Sep 2017
    15
    I'm late to the party.
    I thought Lift Spoilers were the way to go in high winds... someone once suggested strapping a few pool noodles to the leading edge. Or is the concern too much wind on the rudder?
  15. #55
    2,011
    They do help I have a set of mesh covers with lift spoilers on them, but you still need a good tie down when the wind blows hard.
  16. #56
    2,210
    Spoilers on top of the wings help reduce overall lift but there's still some wind that pushes on the wing's bottom and tail. Swirl's around and buffets the entire plane. If there's loose snow blowing the wind's pattern can be seen. Solid covers unless vented or made of mesh will blow up off the wings and can damage the trailing edge and controls by getting too tight. Cessnas and others can end up with bowed tops to the ailerons as a result of that wing cover tension.
  17. #57
    5,129
    New improved Duckbills.
    Thanks cubflier, WindOnHisNose thanked for this post
    Likes 46 Cub, TurboBeaver liked this post
  18. #58
    2,210
    The design's stepped end mimics some of the newer ice spuds used to open holes for fishing. They gradually penetrate hard surfaces rather than the whole end trying to go though all at once.
  19. #59
    Doug Budd's Avatar
    Feb 2015
    Crawford Nebraska
    180
    Had my pacer tied down in Dickinson ND with heavy duty racket straps. The forecast was calling for 70mph wind with higher gusts. Made me nervous so I bought some rope and double tied all three corners. Glad I did wind blew at 90 degrees and two straps failed the rope saved my plane. Now I donít use straps, they start to fray then tear
  20. #60
    2,210
    Unless twisted along their length flat straps will flutter and can fail.
  21. #61
    3,573
    Yah, like Tacoma Narrows Bridge - ha!
    Shanghai Tower (super-tall) has a twist to it, supposedly for that same reason (vortex mitigation). https://www.google.com/search?q=shan...QL0Ex73P695SM:
  22. #62
    2,210
    Von Karmen shed vortices are a contributing factor.
  23. #63
    RVBottomly's Avatar
    Sep 2017
    797
    Right. I learned that from hay truckers long ago.
    Thanks Coulee Clipper thanked for this post
  24. #64
    3,102
    ….. The tail tie down failed because I had it fastened to the tail spring loaded handles. The 60+mph first gust ripped the eye off of the handle leaving the claw in the ground. When the plane spun 180 into the wind, it pulled up the Wing Claws. …...
    I've seen this kind of thing in different type of failures,
    most notably, a scaffold-- one support was hit by a truck and collapsed,
    bringing down the whole structure.
    It was fine, however, until that first support was damaged.
    I'm curious why you fastened to the eye(s) in the pull handles?
    Do you not have the eyebolt where the tailwheel assembly attaches to the stinger?
    That, or the t/w fork or head itself, seems to me to be the best attach point(s).
  25. #65
    TurboBeaver's Avatar
    Jun 2009
    Northern Maine
    786
    Dont forget a very important factor to holding a Cub in winds in excess of 50kts is the flimpse piece of channel that conects your spar to your strut is the fuse........ Hundreds have failed over the last 65 years. The best ropes and tie downs are useless to you, when this part fails. Atlee has two different cures. Either modify yours or its simply a matter of time before you
    will learn the hard way........
    Thanks Colorguns thanked for this post
  26. #66
    Aug 2014
    23
    Hello,
    Interesting thread. I was curious if there is a final ranking AV consumer didnít test the claw that I use.
    I bought a claw based on recommendations, but I thought I heard that at SnF it was a claw on the husky that flipped. Could be wrong.
    Abeís looks like a cool design. This is new to me.
    My wife use to use a dog tie out auger. She said it is cheap and hasnít let her down yet. Then again she hasnít tested in some of the winds you all are talking about.
    The duckbills looks light and easy but I wonder about cost. I suspect I would lose these over time so they could end up costing more than the other options.
    I wonder if some work better in different soils clay versus sand. Anyone pick their tie down based on the soil they are expecting. I ask because I thought augers are the least strong, but one of the comments above said they use an auger for Sandy soil? Should I throw my wifeís augers away or do they have a purpose for some soils?
    Secondly. I didnít understand about the pool noodles to break air flow or a spoiler. Sounds interesting but I canít visualize how these would get attached. My fear is they will come partially loose and whip the wing all night. Anyone have a picture?
  27. #67
    Colorguns's Avatar
    Dec 2013
    Bloomfield NY
    358
ID:	45818Sewed a 9-10” sleeve on top at the crown of the wing. Insert the noodle then put the wing cover on the wing. Takes about 6 minutes each to install. Haven’t done thieves lot and sure it will go fast with practice.
    this is what Turbobeaver is talking about.
    Thanks Tnathan thanked for this post
    Likes RVBottomly, TurboBeaver liked this post
  28. #68
    2,011
    I buy duckbills 30 at a time so I get a bit of a discount. I make up sets of 3 and put in plastic ziplock bags. The final cost is 25 dollars a set, I use 1-3 sets per year. The cost is nothing compared to that damage that could be done if the wind comes up. YOU GET WHAT YOU PAY FOR when it comes to anchors.
    Likes Chicken Hawk, TurboBeaver liked this post
  29. #69
    2,210
    If using dog rope augers try putting two or three (best) in at each wing or tail tie down. Screw them flush with the ground and spread them out in a triangle a couple feet apart at least. Connect them with rope or cable from each to a flat central point in the middle of the triangle. Tie your ropes or cables to that point - a heavy steel ring makes a good attachment. If the wind blows the rope to the wing or tail being pulled up will try to pull the three anchors sideways towards each other and not as much up. They'll hold better under a side than a vertical pull.
    Gary (uses duck bills and ice screw anchors plus wing spoilers)
  30. #70
    Sep 2004
    Anchorage
    454
    For us with floats..........one big advantage to duck bills is you can drive them into a lake or stream bottom.
    If the wind comes up and you're on a beach with the floats rocking back and forth against the bottom or shoreline go drive some duck bills in deeper water and pull the plane off the bank and tie it down faced into the wind.
    Can't do that with other tie down systems.
    I am with Denny, the cost is cheap. And they flat out work.
    Just make sure you have a good driving rod and that's long enough.
  31. #71
    5,129
    I've had no luck with Duckbills in water saturated soils. FWIW.
  32. #72
    aktango58's Avatar
    18AA
    9,290
    we got between 1,500 and 1,800 pounds on a pull test in saturated sand (glacier till) when we did our pull test with them. To get that we drove them four feet into the ground, which is not practical without having machinery to drive them. Not much will hold in saturated soils, no matter what you do. A sheet of plywood buried would be your best bet there.
    Likes DJG liked this post
  33. #73
    Sep 2004
    Anchorage
    454
    Huh, I've not had any problems other then them eventually rusting. I have them in Lake Spenard, in Shulin Lake and even had some in the mud on the Deshka by the ADF&G cabin (adjacent to the island). All those have held over the years. The only place they wouldn't work would be the pond at the Kustatan. Not much works there when it's wet.
    Since the dock floats and is 64 feet out in the lake I use them at the end with a chain to keep the dock straight. No pipes or posts sticking up to hit that way.
    I guess I've just been lucky.
    I don't use the tiny ones, I use the medium sized ones that AIH carries.
  34. #74
    4,032
    Where do you guys buy the duckbills from?
  35. #75
    2,011
    Arctic wire and rope is the best price I have found in Anchorage. If I was in the lower 48 I would do amazon.
  36. #76
    2,210
    Full size ducks in wet soils or underwater are the best unless electrical pole tie screws are used. It takes 3' or more and even then a railroad jack can slowly pull them out...side loads are best so don't install them vertically under the tie down locations. Most up loads are not a steady pull and use two or more spaced apart for best strength. Stainless cable lasts and doesn't corrode. After years and galvanized can rust out at the thimbles if the water/upper bottom soil interface goes anoxic and low pH sulfide compounds create acids.
  37. #77
    Vermont
    318
    Why so little interest in tail stands? I would think the first thing would be reducing wind load in the first place. Perhaps a more easily stowed post guyed 3 ways.
    What's a go-around?
  38. #78
    19,607
    Quote Originally Posted by Tnathan View Post
    Hello,
    Interesting thread. I was curious if there is a final ranking AV consumer didn’t test the claw that I use.
    Abe’s looks like a cool design. This is new to me.
    My wife use to use a dog tie out auger. She said it is cheap and hasn’t let her down yet. Then again she hasn’t tested in some of the winds you all are talking about.
    I wonder if some work better in different soils clay versus sand. Anyone pick their tie down based on the soil they are expecting. I ask because I thought augers are the least strong, but one of the comments above said they use an auger for Sandy soil? Should I throw my wife’s augers away or do they have a purpose for some soils?
    Secondly. I didn’t understand about the pool noodles to break air flow or a spoiler. Sounds interesting but I can’t visualize how these would get attached. My fear is they will come partially loose and whip the wing all night. Anyone have a picture?
    I was at Sun & Fun and I don't think anything would have saved some of those airplanes short of a few box vans blocking the wind.
  39. #79
    19,607
    Tractor Supply here has them.
  40. #80
    10,901
    I used them as tiedowns in Fairbanks for ~ twenty years IN the float pond, to secure Cubs and Cessnas up to 206 on floats, and on shore on wheels. They were in there for years. After ten years or so, i augmented the early ones that had galvanized cable with ones with stainless. But, after twenty years the ones with galvanized cable were still stout.
    These went through some pretty serious gusty winds from T-Storm outflows. Which also creates wave action, to work against the anchors. I never gave a thought to whether they’d hold, there was never a doubt.
  1. Replies: 17
    Last Post: 02-27-2018, 06:24 PM
  2. Replies: 9
    Last Post: 12-18-2015, 12:48 PM
  3. Replies: 15
    Last Post: 12-13-2015, 11:03 AM
  4. Replies: 1
    Last Post: 10-13-2014, 06:06 PM
