cubdriver2
Don't be too quick to say this. When I was working for a flight school, one of the students managed to ground loop a Cherokee.
Sounds like he's qualified
PRESS RELEASE - CUBCRAFTERS NOSEWHEEL XCUB HEADED FOR PRODUCTION
Public Market Survey Effort Complete
Yakima, Washington – June 18th, 2020: Following a year-long public Market Survey effort, light aircraft manufacturer CubCrafters has officially decided to certify and offer a nosewheel option for its flagship Part 23 certified aircraft, the CC-19 XCub.
“Putting a nosewheel on a modern Cub type aircraft certainly surprised some people, but the overwhelming public response has been positive, especially among the more than 300 pilots that have had the opportunity to fly the airplane during the Market Survey phase,” comments Brad Damm, CubCrafters VP of Sales & Marketing. “A nosewheel equipped XCub is a very easy airplane to fly that takes off shorter, lands shorter, and cruises faster than the tailwheel version. Once a pilot is in the airplane and experiences it, the advantages are obvious.”
“Engaging our customers in a Market Survey effort for this new nosewheel option has been hugely important,” says Patrick Horgan, President of CubCrafters. “We went into this process not entirely sure if the market wanted to accept a nosewheel-type personal adventure Cub. There is no question now; we’ve had people wanting to place deposits for this aircraft from day one. Our customers have made it very clear that they want us to build this airplane.”
The company also notes that hundreds of hours of real-world use by a variety of pilots of varying skill levels during the Market Survey phase led to many design improvements that wouldn’t otherwise have been possible in an internal-only development setting. Current and prospective customers were able to have a large influence on the final design of the nosewheel option for the aircraft.
“The added capabilities and value offered by the new nosewheel option are game-changing” continues Horgan. “The XCub is easily convertible between nosewheel and tailwheel, so you really get two airplanes in one. A fast, modern, easy-to-fly, tricycle gear aircraft and a traditional big-tire tailwheel Cub together. Both are very capable STOL aircraft designed for the backcountry missions that CubCrafters’ airplanes have always excelled at.”
With an extremely robust trailing-link nosewheel assembly and large tundra tires as an option for the mains, the nosewheel equipped XCub is capable of handling primitive landing strips and most off-airport type operations. Landing loads on the nosewheel are transmitted to the airframe by a heavy duty truss designed just for this application, and the entire nosewheel assembly itself is a bolt-on option that can be removed should the owner want to convert the airplane to a tailwheel configuration.
“This is something I’ve looked forward to for a long time,” comments Jim Richmond, CubCrafters’ Founder and CEO. “I’ve always believed that back-country flying should be open to more than just tailwheel rated pilots, and it’s exciting to see that vision now becoming a reality!”
The XCub program has achieved a number of significant milestones in its short history. After initial FAA certification in June of 2016, the XCub was the first United States General Aviation aircraft to achieve non-TSO’d avionics approval for the Garmin G3X system in 2017. In 2019, CubCrafters collaborated with Lycoming and Hartzell to offer the new light weight CC393i fuel injected 215 horsepower engine and a new high performance PathFinder 3-bladed composite propeller, for the XCub.
Badged as the “NX Cub” for aircraft leaving the Factory in the nosewheel configuration, the new tricycle gear option is available now on experimental XCubs through the company’s Builder Assist program, and CubCrafters expects to achieve FAA Part 23 certification in early 2021.
I have a lot of off airport time in big tired 182’s, 206’s and 207’s. I would think most recreational missions will work just fine with the third wheel in the wrong, I mean different, location........
I agree, especially in Utah and Idaho. All that power will help with the high density altitudes. That nose wheel might be an issue around here.
View attachment 49494[/Q
Steve, you could put a cow catcher on the nose wheel like on a train and keep the dogs safe!
I was interested in the claim that the nose wheel configuration made it faster, and produced better STOL performance. I have to believe a Pacer out runs the venerable Tri-Pacer.
A stock Pacer vs a stock TriPacer with the same HP, the TriPacer will get off the ground faster than the Pacer. The tri gear allows it to rotate to a higher AoA and produce sufficient lift at a slower speed.
I learned that the hard way. 8)This might vary depending on the surface. On pavement for sure, but if the little wheel upfront was dragging in he sand?
