Results 1 to 9 of 9
Thread: Drag Wires
    Dec 2018
    Hysham, Mt
    13
    Drag Wires
    Guys: Im starting to order some stuff for the Cub project. Im a bit confused about drag wire size. I was thinking 1/8 as a 6-40 nipple is supposed to thread on the ends yet the holes in the strut are drilled for 3/16 where the #4 compression strut is located. Plans say to place drag wire inside the compression tube. Now Im confused.....are we talking 1/8 or 3/16 or are we saying 1/8 goes in the four bays and 3/16 goes inside the compression tube?
    Thanks for any guidance,
    Sarpy Sam
    10,262
    Flavor of wings you are attempting to describe????
    Dec 2018
    Hysham, Mt
    13
    It’s the Wag Aero sport trainer.
    Sarpy Sam
    10,262
    Quote Originally Posted by Sarpy View Post
    Its the Wag Aero sport trainer.
    Sarpy Sam
    sorry, no experience with that version....
    you might post pictures of the plans you are in question about???
    RVBottomly's Avatar
    Sep 2017
    496
    I have 2+2 plans and Wagabond plans. No sport trainer plans. But the Wagabond plans have something like what you are talking about:
Name:	wag wing cropped.jpg
    I added the red arrow to what looks like a drag wire going through a compression strut. I have no idea about that arrangement. The 2+2 I'm building has an "N" strut there instead.
    The drawing doesn't seem to specify the size wire. I do note that the sport trainer wing kit has drag wires of different lengths. Probably a good idea to call Wag to find out the size.
    Vic
    RVBottomly's Avatar
    Sep 2017
    496
    Here is the full drawing of the Wagabond wing, if that helps.
    Dec 2018
    Hysham, Mt
    13
    Quote Originally Posted by RVBottomly View Post
    Vic
    thanks for the interest Vic. The plans dont seem to specify the size as far as I can tell. The Piper Service manual calls them a 6-40 rod which I think is 1/8 with 40 threads / inch. I can live with that but why call for a 3/16 hole for the drag wire located inside the #4 compression strut at the lift strut fitting? It sure seems to me that that should be a 1/8 hole.
    your plans are quite similar to mine except that Ive got the longer wing with one more set of drag/anti drag wires.
    Sarpy Sam
    RVBottomly's Avatar
    Sep 2017
    496
    I think 6-40 is slightly larger than 1/8". Like 9/64" ?
    Sent from my SM-J320V using SuperCub.Org mobile app
    Dec 2018
    Hysham, Mt
    13
    Vic: I had originally looked for 9/64” rod but put the mic on the wings that I’m disassembling and come up with 1/8” on the drag wires. Since the wings are supposed to be ‘39 models, I wonder.... They’ve been repaired numerous times and I couldn’t prove that they’re original.
    Sam
  1. Streamline vs round drag wires
    By Den in forum Super Cub Repair Facilities
    Last Post: 11-22-2012, 04:46 PM
  2. Drag, Anti-drag wires...
    By fobjob in forum Modifications
    Last Post: 07-08-2011, 01:48 PM
  3. Vertical Beams on Dakota Cub Ribs Interfere with Drag Wires
    By James L. Smith in forum Cafe Supercub
    Last Post: 07-18-2006, 08:43 AM
