Results 1 to 16 of 16
Thread: Small Continental Pushrod Spring Clamp Pliers
    nd
    3,723
    that little spring clamp that holds the pushrod seal in place can be pretty pesky to squeeze the 2 ends together to slide on or off the seal. i use a pliers now that i ground some grooves in but still not 100 percent, not even 70. anyone use something where you tell yourself this works?
    mike mcs repair's Avatar
    11,773
    been years(decades?) since i used these last, but I bought 2 sizes of these 30+ years ago...
    https://www.gibsonaviationok.com/tools
    is that what you mean???
    nd
    3,723
    https://www.ebay.com/itm/Chevy-Radia...UAAOSwazpdJXF6 a tool for squeezing these so when there squeezed they dont go flying off, the continental 1 1/2 inch clamps are pretty stoudt. learned the clamps are called Corbin clamps.
    CubCruiser's Avatar
    Jan 2009
    Apollo Beach, FLA www.KidsFlyCubs.org
    180
ID:	43758Click image for larger version.
ID:	43759Click image for larger version.
    19mm or 3/4” deep socket, .041 safety wire and a vice work nicely if you don’t have the magical pliers.
    Daryl
    Daryl Hickman, ATP, CFI, XYZ, PDQ
    N452SP American Legend Cub
    N333DH American Legend MOAC (in process)
    http://www.CubFlying.com
    http://www.KidsFlyCubs.org
    Jul 2010
    Elizabeth, WV
    583
    I'm assuming you mean the original pushrod rubbers on the small Continentals
    I bought these Craftsman pliers new years ago and they work. I think they are now obsolete. The weak part is my grip and not the pliers. Sometimes I need to spray a little WD40 on the rubber to get the clamp to seat correctly. I also inherited an old worn pair. They are unusable when they get worn even a little and should be thrown away. I keep them just for the guy who is too cheap to buy his own tools and sells off good tools whenever he gets them in a trade so he always needs to borrow something.
    https://www.ebay.com/itm/Craftsman-8...0AAOSw0w1ct9Os
    K-D makes a pair like these. I have thought they might work well but never got around to buying a pair. I thought the groove was cut on both of the rotating jaws.
    https://www.ebay.com/i/273745935893?...SABEgJwyfD_BwE
    nd
    3,723
    thanks, learning both about the small block and big block engines here.
    11,773
    I have a pair of those KD ones in my tool box. Must be what I had them for. Haven’t used them in many decades....
    11,773
    Guess mine are craftsman brand. Click image for larger version.
ID:	43766Click image for larger version.
ID:	43767Click image for larger version.
    nd
    3,723
    the problem with all the commercial ones, is they make the prongs come together on top of each other instead of side by side, so you always have to beware. if the prongs came together side by side it would also make the clamp open a little bigger. this is no big deal.always get it done. just thought someone had a improved or modified idea. going to make one so the prongs can be squeezed side by side. mike ive tried what you have, there about 75 percent efficient. got to add, for the continental application.
    nd
    3,723
    see how one side of the end is directly over the other, instead of this, one should be to one side and one to the other. the v,s should be offset.
    Aug 2014
    Kenai, Alaska
    198
    Just replace the pushrod tubes with the Real Gaskets STC'd version, similar to Continental 470/520 pushrod tubes.
    nd
    3,723
    seen the 0-200d engines uses these, didnt know you could use them on the other engines?
    Likes eskimo77 liked this post
    flyrite's Avatar
    Mar 2013
    Lyons,GA
    508
    Doug, Below is the compresor tool for the new style pushrod tubes. Having had both , I can tell you I like the new style much better. Can pull the tubes without removing the cyl.
    With nearly 300 hours on the overhaul they have been Maintenance free. also provides for one of the dryest engines I’ve ever had. My experence with the old style was it leaked oil from one or more constantly.
    11,773
    Quote Originally Posted by flyrite View Post
    valve spring compressor for small engines...
    7,441
    Those are a better idea. My only experience was straightening out an installation done by another mechanic. The Tennessee STC holder was very helpful. As I recall, a collar was installed backwards.
    The guy doing the original work - insisted that the lifters had to be collapsed and clearances measured because that has to be done each time a cylinder is removed. Not sure whether he did the AD. Same guy took the brand new greased Grove wheels off and re-greased them. I was horrified. He said wheels have to be greased at annual.
    Better to put the collars in the right way. Opinion.
    Mine is a J3. My only concession to originality is red ignition wires to match my stripe. I use two tiny worm-seal clamps on each pushrod rubber, and have no leaks. I do have the expander tool for the cylinder end, but rarely have to use it.
    HendersonClaire's Avatar
    Mar 2021
    2
    Well, the original pushrod pads can sometimes fly off. I had to change them a couple of times because I was constantly getting my fingers slapped. It was unpleasant. I threw them for a long time and used other pliers (which my grandfather gave me, very old but reliable). Have you tried spray guns before changing these pads? Sometimes it is enough that the clip does not fly off and does not move. I learned this from the Home Improvement tips. It was useful to read stuff on various sites about tools, homes, and construction. I even got a couple of other tools that I never had before.
  1. Small bore Continental parts
    By md11freighter in forum Parts and Pieces
    Last Post: 03-12-2019, 12:34 PM
  2. Real Gasket Pushrod Tube Seal Kit for small Continentals
    By skywagon8a in forum Super Cub Sick Bay
    Last Post: 09-25-2015, 06:57 AM
  3. Great website for small continental engines
    By scout88305 in forum Cafe Supercub
    Last Post: 03-12-2007, 08:09 PM
  4. Tailwheel Spring Clamp...
    By marlboro in forum Experimental Cubs
    Last Post: 01-28-2007, 05:15 PM
