180 slant bladder sensing unit gasket source?
supilot
FRIEND
What is a good source of these gaskets? I’m not having much luck. Thanks!
Someone told me to try a Rochester Gasket for a mechanical fuel gauge (BUNA A) P/N 15-4. Spruce has them, so will see tomorrow if they work or not.
If EI sells a gauge they should have gaskets???
Why not try Napa? Scott, so it’s a tractor gauge too???
Yeah I’ll try NAPA.
Univair sells a gauge, but won’t sell the gasket solo.
EI said they don’t provide a gasket like that over the phone.
Thanks.
Scott’s parent company mentioned in Univair’s page might be worth contacting
Thanks Mike. I just zoomed in on the univair gauge and realized it says Rochester Gauges now. Looks like they sell lots of gauges (non aviation) with same bolt pattern and they sell the [FONT=&quot]Buna-N, [/FONT]0015-00004 gasket to go with them. That’s what I ordered from spruce thanks to a PM from another member. Will know tomorrow if that’s a $3.65 solution.
Totally not the company I was referring to... but if it gets you what you need, great!
attachment.php
Are you certain that is not just a flattened "O" ring?
