Thanks Thanks:  0
Results 1 to 9 of 9
Thread: The Sensenich ground adjustable prop info
    Oct 2018
    50
    Hi Everyone,
    Looking for anyone that has flown or tested out the new stol Sensenich ground adjustable prop for the 0320 in a super cub? Would love to know how it stacks up to the Whirl Wind ground adjustable. Thanks in advance for any info!
    Feb 2015
    Anchorage
    41
    You experimental guys get all the good stuff!
    Farmboy's Avatar
    Jan 2016
    Glens Falls, NY
    2,367
    Tim Allen has a whirlwind I believe and really likes it. I had a sensenich on my C-90 and loved it as well.
    Personally I think with today's composite designs, and the ability to dial in the exact pitch that fits your airplane and your mission, it's pretty hard to miss with any modern/current composite ground adjustable. My C-90 cub was a complete different airplane with it.
    pb
    Oct 2018
    50
    pb
    Thank you! Its funny you can find some stuff on the whirlwind ground adjustable prop but not the sensenich? Just sounds like the Sensenich prop is a lot easier to adjust the prop angle well and more $$.
    supercrow's Avatar
    Dec 2008
    373
    Just started using the Whirlwind this spring on wheels in cool weather and made one adjustment to get it where I wanted it before I put the floats on. Worked very well until recently as we have had some really warm weather and I find it a little flat now. Going to put a degree of pitch into and go from there; but so far I like it because I can make it work for whatever the mission is. Takes as long to put the spinner on and off as it does to adjust the prop, but no big deal anyway. I think it was a good move for me. This winter on skis in cold weather I might have to back it off a bit; but it will be nice to have that option. If it is tough enough and holds up over time, I think it will be a great prop. Will give you more as I use it.
    Oct 2018
    50
    Thank you you for the info! I live in Texas and itís so hot in the summer! Iíve got a cruise prop on mine and with the heat it doesnít like to climb out of its shadow. Looking for the best climb prop + the adjustability would be awesome!
    Feb 2020
    2
    Any update to this? I am looking at a sensenich STOL prop for an 0360 because it looks easier/faster to adjust vs. the whirlwind, assuming they preform the same. But if the whirlwind preforms better I'll deal with the time it takes to adjust. Any pro's/cons of either?
    10,093
    Quote Originally Posted by handytravis View Post
    I have the Whirlwind 200G https://m.whirlwindaviation.com/props/STOLGseries.asp on an IO-360. This is the heavier 43 lb. version. It only takes a minute to change the pitch with two "T" allen wrenches through a hole in the tip of the spinner. Performance is awesome. The only regret is that I can not install a governor and have a constant speed prop. The blade shape was designed by the late Paul Lipps who managed a lot of race wins with his designs.
    http://www.rexresearch.com/lippsprop/lipps.htm
    https://www.homebuiltairplanes.com/f...opellers.4911/
    http://www.aafo.com/hangartalk/showt...ter-and-sundry
    https://www.flyinggiants.com/forums/...t=56581&page=3
    http://www.aviationbanter.com/showthread.php?t=2535
    Feb 2020
    2
    I was planning on the whirlwind GA200L, the lighter version vs. the sensenich stol prop. I would like to know if the sensenich is as good as the GA200L as I've seen that in action on a 0320 and was impressed. I lean towards the sensenich, but if the whirlwind preforms better, i'll get that one- please help....
  1. Sensenich stol ground adjustable props
    By scottsville in forum Cafe Supercub
    Last Post: 06-23-2019, 09:18 AM
  2. Sensenich ground adjustable prop
    By TcraftF21 in forum Products, Purchases, Reviews & Prices
    Last Post: 01-17-2017, 10:41 PM
  3. Sensenich 2EK Ground Adjustable Prop
    By R. JOHNSON in forum Experimental Cubs
    Last Post: 12-04-2008, 01:13 PM
