Results 1 to 18 of 18
Thread: New Nose Bowl w/ No Holes
    19,506
    So in the process of building new cowling on a Super Cub with a Sutton exhaust and the Thrustline modification we decide to buy a new 12355-5 nose bowl without any cut outs. Fit great, no need for the front oil cooler scoop nor the starter hole since we are using a rear mounted cooler an a SkyTec NL starter. Well then I find out about this starter that saves 2.9 lbs and has been giving good service to several of my Super Cub friends. Had someone in need of the NL starter, installed the new XLT starter all was good. Wrong. When I removed the new nose bowl I noticed a little dimple where the nose of the new starter hit. The XLT starter has a nose bushing support where the NL does not. Every change effects 2-3 other things. So I took a 3" hole saw and cut a hole in a 2x6, sanded the edges and made a fixture to bump a dimple in the new nose bowl. Some hammer work on the fixture, then on a shot bag and finished out with a few different slappers and we now have good clearance. Adapt and overcome.
    Jul 2012
    Montana
    438
    thats so funny, I had the same issues, but instead of using all those tools and sand and stuff, I now just have a dent in my new nose bowl that is starting to flake a bit. Steve you are a true professional I enjoy reading. Thanks for showing off
    doug
    Dave Calkins's Avatar
    Jul 2002
    Anchorage, Alaska
    5,405
    sweet!
    I woulda used a router with a round over bit instead of a sander. SMILE
    Dave......Waiting on fog in Bristol Bay
    19,506
    I just sanded it by hand but the router would be a better deal.
    Farmboy's Avatar
    Jan 2016
    Glens Falls, NY
    2,372
    Very nicely done.
    45
    Will the spinner clear the bump?
    4,014
    Will the NL hit the nose bowl?
    PerryB's Avatar
    Aug 2007
    Chico, CA
    1,956
    It would'a wore itself it eventually. I don't see what the big deal is. Given time, most interference items will self-clearance....
    19,506
    No, the NL was Jason's original starter and there was no issue with it hitting prior to the bump.
    19,506
    Jason didn't like the bump so I made a doubler out of some .125" think aluminum, formed it to the nose bowl and riveted it in and formed a hole around it. Now it looks stock.
    4,014
    Thanks. Was replacing the one on FMD’s cub and the NL looks close to the nose bowl
    Dec 2016
    Canyon, tx
    524
    Hell, I liked the bump. Reminded me of my high school girlfriend. I’d have you Fedex it to me but no telling if it would ever make it here.
    19,506
    I thought you paid good money to have those recreated? This one got smashed flat with a body hammer.
    Dec 2016
    Canyon, tx
    524
    Surprising enough, P-stol flaps and 350cc lady bumps cost about the same.....money well spent
    txpacer's Avatar
    Jun 2011
    Iowa Park, TX
    733
    You really shouldn't cheap out on either one. Go for the best you can get.
    Likes Farmboy liked this post
    TurboBeaver's Avatar
    Jun 2009
    Northern Maine
    782
    The Pstol flaps will draw some attention, from a limited audience;
    A set of 350CC " Lady Bumps" will
    draw major attention worldwide to a massive part of the population ( both genders!) and likely get you into some
    places that Pstol flaps just wont!
    Likes FdxLou, Bender liked this post
    19,506
    You really shouldn't egg him on.
    Thanks KevinJ thanked for this post
    3,079
    Jason didn't like the bump so I made a doubler out of some .125" think aluminum, formed it to the nose bowl and riveted it in and formed a hole around it. Now it looks stock. ...
    I thought the bump looked great.
  1. Nose Bowl
    By Roger Peterson in forum Cafe Supercub
    Last Post: 01-02-2012, 02:59 PM
  2. Sport Cub Nose bowl
    By snowyriver in forum Cafe Supercub
    Last Post: 07-25-2008, 12:59 PM
