Results 1 to 5 of 5
Thread: Fuel Tank Installation Question
    22
    I am putting in the fuel tanks on my experimental PA18 Clone. They are the 18 gal ones. Question is if any one has a trick to putting the front bolts in the fuel tank cross member? I got the rear ones in and tight, and got the front ones in, washer on, and nut started, can not see a way to tighten it up. Any help would be appreciated. Also, the fuel tank covers, do they lap over the gap seal or the other way. Pictures I look at seem to have them both ways. I looked at plans, and just not clear.
    Thanks stknrddr thanked for this post
    6,866
    Good question. I think our forum members gave me the answer last year. Getting old, but as I recall, you do the front bolt before you slide the tank in, and the rear afterward.
    Also, getting those straps bolted together is a two-man job.
    10,574
    you put in front bolt first and snug it...
    then you put tank in
    then you line up rear bolt with bent punch, vise grip it, remove punch, install bolt & nut and tighten
    22
    Thanks guys, was hoping for an easier way, looks like I will be taking the tanks back out and try this. Seems I usually get to do things two or three times on this build
    10,574
    Use a small head nut
  1. Fuel Tank Question
    By Evan in forum Member to Member
    Last Post: 05-20-2011, 05:27 PM
  2. Pa-16 Clipper fuel tank question
    By Floatin_around in forum Super Cub Sick Bay
    Last Post: 04-22-2006, 08:46 PM
  3. Dodge Tank Installation Question in PA12
    By rsmarch in forum Modifications
    Last Post: 04-24-2004, 09:26 PM
