Results 1 to 6 of 6
Thread: What is this called?!!!
    Jun 2018
    England
    404
    Can anyone please tell me the correct name for the fitting that's bolted through and sticking up from the Tailwheel steering arms in this pic please? I'd like to order some for my TW and Rudder steering arms, to reduce the vertical angle the TW steering chains are currently in. Are they available in different lengths too?
Name:	Screenshot 2019-06-10 at 10.42.27.jpg
    Thanks!!!
    Philly
    RaisedByWolves's Avatar
    Feb 2005
    3,983
    Jun 2018
    England
    404
    Thank you!!
    They all look to have the same height of drilled plate, so I guess the way to go to make the drilled hole higher from the TW steering arm would be to order the correct overall length and pack out the additional height needed between the base of the drilled plate bit and the steering arm with washers or a tube cut to length?
    10,891
    So, what’s the part number for the matching eye bolt with 2 ears?? I know they make them. Got a few. Would like more.
    10,891
    Farmboy's Avatar
    Jan 2016
    Glens Falls, NY
    2,322
    Mike just a threaded end is usually a clevis fork, but not sure on a forked clevis bolt like that with full shoulder.
    Similar to lift strut forks.
  1. FAA Called
    By RCharles in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 10-28-2015, 05:06 PM
  2. What's it called and where can I get one?
    By cabinflyer in forum Cafe Supercub
    Last Post: 03-10-2009, 11:18 PM
  3. I called Lycoming about 100 LL issue
    By HATIN11R in forum Cafe Supercub
    Last Post: 06-10-2005, 08:50 AM
  4. Hoist rings, or whatever they are called
    By WindOnHisNose in forum Modifications
    Last Post: 08-05-2004, 04:36 PM
