Results 1 to 10 of 10
Thread: PA 18 External Load Canoe
    C-FIJK's Avatar
    Jan 2005
    Lewisporte N.L.
    406
    Hi there wondering if anyone here has carried a Square Stern Canoe on a super cub on I am looking at is 15 feet long , I been told anything over 12 is to much for a Super Cub , any advise , pictures if you have done it please let me know Thanks !
    Jun 2008
    sioux lookout
    527
    my exp pa-12 with an 0360 pushing 195hp would carry really ugly external loads, i would say quit a bit better then the cessna. tie it on stern fwd make sure you have good prop clearance ( that may be the problem with a 15'er) you will feel how it wants fly prior to leaving the water. Fold-a-boats are good for day trip excursions also, we have a 14'er that you can barely notice in the air.
    C-FIJK's Avatar
    Jan 2005
    Lewisporte N.L.
    406
    I agree with the above 12-14 would be ok. But the one I just found for sale is aluminum and 15 feet long. I am hoping someone here has done it already!
    Mar 2016
    1,051
    The one thing I would say, the hull is a displacement hull, it will suck down into water at speed, I would expect that it will have it's fair share of downforce in air as well. I would pay good attention especially up front that it can not work it's self away from the plane, nor slide backwards allowing the front straps to loosen..
    I am not sure I would put it on backwards, I would start by slinging it up under the belly to see where it wants to settle.
    There are plenty of engineering considerations that some may express, but in reality it is you who will determine the safety of the load as you taxi test it.
    My thought to not carry it backwards is the stern being wider may have more affect with airflow out of the cowl and may end up being closer to the exhaust. Maybe backwards is right, you will answer that the best.
    C-FIJK's Avatar
    Jan 2005
    Lewisporte N.L.
    406
    The one thing I would say, the hull is a displacement hull, it will suck down into water at speed, I would expect that it will have it's fair share of downforce. I would pay good attention especially up front that it can not work it's self away from the plane, nor slide backwards allowing the front straps to loosen..
    Hi there I do know that the square end has to be forward at all times and as close to the prop as possible , next it has to be tied to the struts on the out side , never underneath the spreader bars , I am just seeing if anyone has ever hauled a 15 footer on a super cub Thanks !
    Mar 2016
    1,051
    I had not seen mention this was on a seaplane.
    10,618
    Do some measuring. Where will the canoe have to be to provide prop clearance? Will that put the bow right up close to the tail feathers?
    Ive carries lots of canoes on various airplanes, and for the most part, you don’t even know they’re out there in flight. Take a short test hop, in a place where you can approach to land nearby with no obstacles. See how it flies on that short hop, then go from there.
    Longest canoe I’ve carried on a Cub was a 14.5 foot. Didn’t cause any untoward characteristics. Use good strong ratcheting cargo straps to secure.
    I have no idea what the rules are in Canada, Eh? So check that out as well.
    Sep 2004
    Anchorage
    443
    Is this a one time thing, ie haul it into your cabin and leave it there or do you plan to fly around with it tied on a few times a year ?
    I might bind a load together with ratchet straps, like 2x6's or 2x4's and put on the spread bars but I don't use them to secure the load to the floats. I use good quality cotton rope and cinch it down tight. When it gets wet it really binds and won't bend anything like a heavy duty ratchet can.
    The old green coleman scanoes were 15' and hauled those. For the Coleman scanoe I had a couple of pieces of 1/4" plywood cut to shape and I'd screw that down to the aluminum top rail. Then I'd put that covered surface down on the spreader bars and tie it on. That canoe flew quite a bit so I perfected the method to get it around.
    Likes mike mcs repair, Brandsman liked this post
    TurboBeaver's Avatar
    Jun 2009
    Northern Maine
    719
    Back when the aluminum Gruman Canoes were popular, they had 15' and the 17' ers. The latter was called
    the "Princess". All the flying services
    around here hauled them everyday. Hauling two 17fters at the same time was no big deal on a Cub; but considered "tricky" bussiness on the
    C 180! I tryed hauling a 20' Mirrorcraft
    Boat on the Beaver and found it to be
    more than just........"tricky".
    C-FIJK's Avatar
    Jan 2005
    Lewisporte N.L.
    406
    all very good advice and myself I have hauled a lot of things with the super cub . I thought best to ask here about the bigger canoe this is a one time flight into our hunting spot as I am tired of hauling a boat back and forth every year , we been using a zodiac but I cant leave that in the bush the bears will get it
  1. External Load
    By T.J. in forum Modifications
    Last Post: 01-10-2005, 01:39 AM
