Results 1 to 26 of 26
Thread: C180 Jacking
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,474
    C180 Jacking
    I know this subject has been broached before. I need to install my bushwheels and my engine hoist method won't work because there isn't enough room between the horizontal legs. I ordered two high lift rams from Northern and want to build something to jack under the gear box. I would like photos and suggestions.
    4,929
    Thanks Eddie Foy thanked for this post
    Likes Dave Calkins, mike mcs repair liked this post
    Nov 2003
    Thun Field, Washington
    785
    Av-Jack by Ace-Air
    6,909
    There is a neat way to grab the gear leg. I think Cessna sold a version, but I re- invented it for my Decathlon using long bolts and leather strips. Because the gear leg tapers, it doesn't slide up the gear leg when jacked from below.
    I could get a photo if you want. Small enough that it travels in the spare tailwheel bag.
    4,929
    Eddie, the tripod has pins that fit the jack base to hold it steady. The top fixture can tilt but has a short tube to hold it on the jack end. Rock solid. It can lift both mains simultaneously but I use it for one side at a time.
    Likes Mr. Ed liked this post
    Jan 2017
    PNW
    38
    This fits between gear legs. Keeps gear from springing inward Works great.
ID:	43230   Click image for larger version.
    Likes stewartb, skukum12, utb 44E liked this post
    180Marty's Avatar
    May 2004
    Paullina, Ia
    2,030
    I like to use an engine hoist with a strap around the engine mount right at the firewall bolt. Plus, the long jack with a padded block of wood under the gear box. A pump on one then the other to keep equal tension. I also like the get the tail up on some pallets to level the plane some so the wood doesn't try to slip. Also, low on fuel and try to tilt the plane before to run gas over to the tank on the opposite side I'm lifting.
    Thanks CamTom12 thanked for this post
    Likes CamTom12 liked this post
    10,667
    I use what Stewart uses. Please NOTE, Thatís a piece of PLYWOOD on jack side with a soft 2x6 or 8 on top screwed together to prevent splitting the 2x wood. Been using that method since the 1980ís.
    4,929
    Caulkins needs to post his folding tripod. That thing is bad azz. Packable, like when you need a buddy to bring it? He can!
    CamTom12's Avatar
    Jul 2015
    Huntsville, AL
    721
    I use an engine hoist and some Amsteel line. Works good, and canít slip off a jack.
    Likes hotrod180, 180Marty liked this post
    4,929
    Have you done it on a remote strip?????
    CamTom12's Avatar
    Jul 2015
    Huntsville, AL
    721
    No... was that part of the original request? I mustíve missed that part.
    4,929
    Nope, but we'd all use overhead hoists until they aren't available. Not available describes 99.9% of my airplane life. In this case Eddie already bought hydraulic bottles.
    CamTom12's Avatar
    Jul 2015
    Huntsville, AL
    721
    Thought this was an interesting method as well.
    Mar 2018
    187
    Quote Originally Posted by CamTom12 View Post
    I use an engine hoist and some Amsteel line. Works good, and can’t slip off a jack.
    Right or wrong, that's what I do too... usually because it's the easiest since I haven't constructed any special tool for it. Knocking on wood to limit these changes to inside the hangar.
    I see some of the local operators do their lifts (at home base) by just lifting with the back side of their engine hoists with a pad just outside the wing strut..
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,474
    I like that. Did you make it?
    Quote Originally Posted by Mr. Ed View Post
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,474
    What about it, Dave?
    19,088
    Eddie, I have one of these jacks in the video and Tom posted pictures of that I do not use. I don't work on 180 so if you need it.
    https://www.supercub.org/forum/showt...0-185-Jack-Pad
    2,857
    I do it the same way, only I use a nylon strap as a choker.
    I've tried a couple different versions of jack points that clamp onto or slide onto the gear legs--
    they always scarf up the paint & you have to worry about "tippiness".
    Or you can hoist at the engine mount (not the lifting eye) as others have described.
    Pretty hard for something to fall off a sling.
    [QUOTE=Eddie Foy;748902] I need to install my bushwheels and my engine hoist method won't work because there isn't enough room between the horizontal legs. /QUOTE]
    I don't understand this comment. What horizontal legs?
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,474
    Found the pics.
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,474
    They are on. It finally dawned on me to put the hoist parallel to the fuselage. Also installed Texas Skyways exhaust extension. They promised me that you could install the cowl with it on. They lied!
    2,857
    Quote Originally Posted by Carey Gray View Post
    Av-Jack by Ace-Air
    https://tlgw.aero/tlgw-specialties/av-jack
    I first saw these at Tom Anderson's booth at the NW aviation show a couple years ago,
    I believe that Vern Goodsell down in Sisters OR manufactures them.
    Very nice set-up, but pretty spendy at $575.
    And not very versatile, seems kinda like a one-trick pony.
    Charlie Longley's Avatar
    Jan 2008
    Arlington, WA
    620
    I bought one of these 15 years ago-
    https://bogertaviation.com/collectio...-aero-jack-kit
    4,929
    The worst idea Cessna ever had. The copy cats aren't any better.
    Nov 2003
    785
    The price of those jacks seem to have almost doubled since I bought one a couple of years ago. Vern sold the design to Anderson, or so I was told.
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,474
    Is it patented?
  1. IO-470 for C180
    By texmex in forum Cafe Supercub
    Last Post: 08-17-2017, 04:59 PM
  2. Jacking Cessna 180
    By bryan albert in forum Cessna: C180/C182/C185
    Last Post: 11-02-2015, 06:37 AM
  3. Jacking Cessna 180
    By bryan albert in forum Member to Member
  4. Jacking .....Up
    By NunavutPA-12 in forum Cafe Supercub
    Last Post: 10-21-2013, 08:39 PM
  5. Jacking a cub
    By dlwoolsey in forum Cafe Supercub
    Last Post: 02-27-2011, 10:16 AM
