Travelair3000
FRIEND
I have a1950 SC with an A7 mag switch. The ground lead to the switch does not have continuity to ground, The switch checks fine.
Does the ground lead in the harness, ground at the mags? I tried continuity at the mags and airframe ground no luck.
I assume the wire is broken between the switch and the mags.
