Results 1 to 12 of 12
Thread: Covering around the rear windows?
    supercub's Avatar
    Apr 2002
    805
    Do you typically put re enforcing tape around the exterior of the D (rear) window. If so, any tricks you can share on how you do it? Thanks
    10,663
    Quote Originally Posted by supercub View Post
    no,
    just be very neat about gluing fabric into the window channels... and glue fully to both sides of interior of channel... or fabric may pull out if not locked in by window...
    mask off interior edge of window channel, so as to keep it nice looking, and not get glue where it will show
    6,907
    I do, but not sure it is necessary. I put pinked tape over everything, including inspection rings and drain grommets. I agree - use care to glue the fabric into the channel. Takes patience, and maybe some wood wedges.
    supercub's Avatar
    Apr 2002
    805
    I'm pretty sure I put tape on my super cub several years ago.........but been so long I can't remember exactly how I did it. How did you curve the pinked tape around?
    Hardtailjohn's Avatar
    Marion, MT
    730
    You can work the tape around a corner with heat, if you have a little patience. I always put tape around windows or anywhere else that the fabric is touching a solid structure.
    John
    Likes supercrow liked this post
    Bearhawk Builder's Avatar
    Aug 2012
    In the woods
    676
    I cut a curved tape from a scrap piece of fabric. Cut to size.
    9,650
    Remember the purpose of the tape is to reinforce the fabric where it gets beat against the window frame structure. It was always done when using Grade A cotton. Now with the modern Dacron fabric which we are using, I agree with mike that it is probably not needed. There was a bias cut tape which made it easy to work around tight curved areas. If you wish to use Dacron, Hardtailjohn's method of using heat will work. Tedious, but doable.
    Dec 2008
    Huntsville, AR
    29
    Quote Originally Posted by Bearhawk Builder View Post
    I just did a Citabria and a PA-11 using Superflite. I cut short sections of paint sticks and wedged the fabric into the window groove and let the glue dry throughly. Then carefully broke the sticks loose from the glue. I didnít use tapes on the Citabria, as the original fabric did not have them, but did on the PA-11. I did like Dave and cut a curved tape and worked it down into the grove just like the fabric. Very tedious, but the glue stick worked well to hold the fabric and tape into place until the glue dried. Some places, the tape or fabric pulled loose with the piece of paint stick, but a putty knife and fresh glue worked it back into place.
    Fabricman
    Likes bob turner, Hardtailjohn liked this post
    6,907
    There you go. Cut tapes out of scraps. Always pink the edges. The Cub has no place that requires bias tape, but if you use it for Gods sake cut the splices out!
    Apr 2009
    AK
    102
    Just pulled cotton off of a factory cover job on a Ď64 -18, and it didnít have tapes around windows. I put them on though...
    Aug 2012
    In the woods
    676
    Wax paper around the end of the stick Marv, works great!
    Hope you're good buddy.
    Quote Originally Posted by fabricman View Post
    I just did a Citabria and a PA-11 using Superflite. I cut short sections of paint sticks and wedged the fabric into the window groove and let the glue dry throughly. Then carefully broke the sticks loose from the glue. I didn’t use tapes on the Citabria, as the original fabric did not have them, but did on the PA-11. I did like Dave and cut a curved tape and worked it down into the grove just like the fabric. Very tedious, but the glue stick worked well to hold the fabric and tape into place until the glue dried. Some places, the tape or fabric pulled loose with the piece of paint stick, but a putty knife and fresh glue worked it back into place.
    Fabricman
    Dec 2008
    Huntsville, AR
    29
    Doing pretty well, Dave. Have my Arkansas hangar under contract for sale, and am moving to Homer, AK. Am buying a lot and building a shop with an attached apartment . Am headed back to Arkansas now to load up the tools I am going to keep and sell everything else. Will be calling in a few days for a small favor! Starting a new fabric business up here.
    Didnít try the wax paper as I was working in Canada and had none handy!
  1. PA-12 extended rear windows like L-21
    By ChickenCub in forum Cafe Supercub
    Last Post: 05-08-2016, 09:40 PM
  2. Rear D-windows
    By EnglishEd in forum Cafe Supercub
    Last Post: 06-07-2010, 03:07 AM
